ACE 20 Module Telnet, SSH not working
edwinchungath
Community Member
Dears,
Looking for your valuable advice for ACE module Telenet, SSH access issue, which is not working. But ping is working on that IP.
here I am giving the configureation details
ACE 20 Image ver. - Version 3.0(0)A1(6.3a)
interface vlan 100
  ip address 172.16.100.58 255.255.255.0
  alias 172.16.100.60 255.255.255.0
  peer ip address 172.16.100.59 255.255.255.0
  no Shutdown
access-list permit_any line 8 extended permit ip any any
In global Conf.
access-group input permit_any
RUH-HQ-FBN3-ACE1/Admin(config)# class-map type management match-any MGMT_CLASS
RUH-HQ-FBN3-ACE1/Admin(config-cmap-mgmt)# 2 match protocol icmp any
RUH-HQ-FBN3-ACE1/Admin(config-cmap-mgmt)# 3 match protocol ssh any
RUH-HQ-FBN3-ACE1/Admin(config-cmap-mgmt)# 4 match protocol telnet any
RUH-HQ-FBN3-ACE1/Admin(config-cmap-mgmt)# 5 match protocol http any
RUH-HQ-FBN3-ACE1/Admin(config-cmap-mgmt)# 6 match protocol https any
RUH-HQ-FBN3-ACE1/Admin(config-cmap-mgmt)# 7 match protocol snmp any
RUH-HQ-FBN3-ACE1/Admin(config-cmap-mgmt)# exit
RUH-HQ-FBN3-ACE1/Admin(config)# policy-map type management first-match MGMT_POLICY
RUH-HQ-FBN3-ACE1/Admin(config-pmap-mgmt)# class MGMT_CLASS
RUH-HQ-FBN3-ACE1/Admin(config-pmap-mgmt-c)# permit
RUH-HQ-FBN3-ACE1/Admin(config-pmap-mgmt-c)# exit
RUH-HQ-FBN3-ACE1/Admin(config-pmap-mgmt)# exit
RUH-HQ-FBN3-ACE1/Admin(config)# interface vlan 100
RUH-HQ-FBN3-ACE1/Admin(config-if)# service-policy input MGMT_POLICY
Gilles Dufour
Why don't you try to use class-default under the mgmt policy-map and assign it globally.
You should also plan for an upgrade to get A2(3.3).
Gilles.
Gilles Dufour
Gilles.
Thank you Gilles
Its started working after add class-default under the mgmt policy-map
Edwin
