Ace 4700 SSL for Device Manager
Steven Bourque
I'm trying to replace the SSL Cisco certificate displayed when users access the 4700 Device manager Web config.
The 'policy-map type management' mode doesn't allow any type of SSL commands. Can someone provide a sample config on how to do this?
All I see is how to terminate SSL with regards to servers. I just want to change the SSL used by the ACE itself.
Sean Merrow
Level 4
Level 4
Changing the ACE 4710's device manager certificate and key is not currently supported.  If this is a requirement for you, I would recommend reaching out to your Cisco rep so they can work on submitting a product enhancement request.
Sean
Sean Merrow
Level 4
Level 4
Sean
Thanks.. That at least makes me feel a little better about my unsuccessful attempts and inability to find any documentation.
