ACE 4710 Configuration problem
peersels187
Hello all,
I am configuring a load balancer from cisco, a ACE 4710.
Load blancing is completely new to me, and i am unexpereinced in this field. It has to be configured for a customer that want to load balance HTTP and RTSP traffic over 4 application servers (Back-end)
I searched alot on google for possible solutions, and got RTSP in some way to work, but http wont work says my customer.
Is there someone that can help me with this issue, cause i am running really low on options here. Underneath is the config that i have already sofar.
If you need a topology of the layout, please let me know and i will try to upload one.
Generating configuration....
logging enable
logging buffered 5
logging host 172.18.251.182 udp/514
logging host 172.18.146.241 udp/514
boot system image:c4710ace-t1k9-mz.A5_1_2.bin
login timeout 30
peer hostname ACE4710-Zabrze-2
hostname ACE4710-Zabrze-1
interface gigabitEthernet 1/1
  switchport access vlan 2000
  no shutdown
interface gigabitEthernet 1/2
  switchport trunk allowed vlan 14,21
  no shutdown
interface gigabitEthernet 1/3
  no shutdown
interface gigabitEthernet 1/4
  ft-port vlan 22
  no shutdown
clock timezone mst 1 0
radius-server host 172.18.252.2 key 7 "01000F175004" authentication
radius-server host 172.18.250.2 key 7 "01000F175004" authentication
aaa group server radius prv_rad
  server 172.18.252.2
  server 172.18.250.2
switch-mode
ntp server 172.18.250.160
ntp server 172.18.251.160
aaa authentication login default group prv_rad local
access-list ALL remark Access for all, permit all
access-list ALL line 8 extended permit ip any any
access-list ALL line 10 extended permit icmp any any
access-list PRV remark Access for Management
access-list PRV line 10 extended permit ip 172.18.0.0 0.0.255.255 172.18.0.0 0.0.255.255
access-list STB remark Access For STB's to Serverfarm
access-list STB line 7 extended permit ip 10.0.0.0 0.255.255.255 172.25.248.0 0.0.0.255
access-list STB line 15 extended deny ip any any
probe tcp Traxis_HTTP
  port 80
probe rtsp Traxis_RTSP
  port 554
rserver host Traxis_FE1
  description FE1
  ip address 172.25.248.2
  conn-limit max 4000000 min 4000000
  probe Traxis_RTSP
  probe Traxis_HTTP
  fail-on-all
  inservice
rserver host Traxis_FE2
  description FE2
  ip address 172.25.248.3
  inservice
rserver host Traxis_FE3
  description FE3
  ip address 172.25.248.4
  inservice
rserver host Traxis_FE4
  description FE4
  ip address 172.25.248.5
  inservice
serverfarm host Traxis
  probe Traxis_HTTP
  rserver Traxis_FE1
    inservice
  rserver Traxis_FE2
    inservice
  rserver Traxis_FE3
    inservice
  rserver Traxis_FE4
    inservice
sticky ip-netmask 255.255.255.255 address source Sticky_Traxis
  replicate sticky
  serverfarm Traxis
class-map match-all L4STICKY-IP_6:ANY_CLASS
  5 match virtual-address 172.25.255.6 tcp range 80 555
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match L7PLBSF_STICKY-NETMASK_POLICY
  class class-default
    sticky-serverfarm Sticky_Traxis
policy-map multi-match CLIENT_VIPS_PROD
  class L4STICKY-IP_6:ANY_CLASS
    loadbalance vip inservice
    loadbalance policy L7PLBSF_STICKY-NETMASK_POLICY
    loadbalance vip icmp-reply active
interface vlan 14
  description Server_side
  ip address 172.25.248.250 255.255.255.0
  alias 172.25.248.1 255.255.255.0
  peer ip address 172.25.248.251 255.255.255.0
  service-policy input remote_mgmt_allow_policy
  no shutdown
interface vlan 21
  description Firewall_Side
  ip address 172.25.255.2 255.255.255.248
  alias 172.25.255.4 255.255.255.248
  peer ip address 172.25.255.3 255.255.255.248
  access-group input ALL
  service-policy input CLIENT_VIPS_PROD
  no shutdown
interface vlan 2000
  description management VLAN and Query interface VLAN
  ip address 172.18.146.150 255.255.255.0
  peer ip address 172.18.146.151 255.255.255.0
  access-group input PRV
  no shutdown
ft interface vlan 22
  ip address 192.168.255.1 255.255.255.252
  peer ip address 192.168.255.2 255.255.255.252
  no shutdown
ft peer 1
  heartbeat interval 300
  heartbeat count 20
  ft-interface vlan 22
  query-interface vlan 2000
ft group 1
  peer 1
  priority 200
  peer priority 150
  associate-context Admin
  inservice
ip route 172.18.0.0 255.255.0.0 172.18.146.1
ip route 0.0.0.0 0.0.0.0 172.25.255.1
snmp-server location "lb_env_traffic"
snmp-server community vnet_device_7Gxp2BdhXJ9Ke group Network-Monitor
snmp-server host 172.18.250.185 traps version 1 vnet_device_7Gxp2BdhXJ9Ke
snmp-server trap-source vlan 2000
snmp-server trap link ietf
I really hope someone inhere can help me out !!!
Best Regards
Peter
Hello Peter,
if it's RTSP not working one it might be that for your kind of traffic you would need to have inspection enabled, please see the example here:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Configuration_Examples_--_Server_Load-Balancing_Configuration_Examples#Example_of_an_RTSP_Load-Balancing_Configuration
if further analysis should be needed then we would probably need a packet capture and to investigate this further inside a TAC case.
Cheers,
Francesco
Francesco Casotto
Hello Peter,
you will have to give us more details and I need to say the foreword that if much troubleshooting will be needed we will ask you to open a TAC SR.
How exactly is not working? Does the browser connect? Does it get an http error?
I see that you are using the same VIP with multiple ports, so I guess that it's covering both the RTSP and HTTP LB, as you are using exactly the same setup for both services then from a LB perspective they should either both work or both fail, unless there is a difference on the servers, like is the web server up and running, is it listening on the same port that the client is connecting to the vip to (so most likely 80)?
Two general considerations:
  • is it really needed to deal with this two services together with the same vip and same serverfarm? It is if you wish that the same client will be stuck to the same server for both RTSP and HTTP connections, if not needed personally I would separate them for clarity's sake so that I would have separate VIPs (same vip different port) and separate serverfarms with different, appropriate, probing for the diferent services
  • it's generally a good idea to perform the LB configuration in other contexts than the Admin one.
Cheers,
Francesco
Thanks for replying Francesco.
Above you can see the layout of their setup.
At the moment HTTP traffic is working but for RTSP it doesnt work.
To follow you on your remarks a bit.
The reason for one VIP i guess is that HTTP and RTSP should be hitting the same rserver. For that reason i created a stickiness and the predictor (under serverfarm) it first was at the default one Round Robin, now i changed this to "HASH ADDRESS SOURCE"
The reason for this is, how the cutomer explains it
When a user gets the catalog on the STB and selects a VOD movie to watch, he does a purchase.
When the purchase is completed he tries to start watching the movie
Say the purchase and the watch both end up on a different server. Then the server who receives the watch command doesnt know the user purchased the VOD movie and returns an unauthorized message. Which results in the user not being able to watch his just bought movie.
So both HTTP and RTSP requests should be received at the same rserver.
About the Admin context, i thought about this, but the customer doesnt wanted it in another.
Below you find the new updated config :
ACE4710-Zabrze-1/Admin# sh run
logging enable
logging buffered 5
login timeout 30
  no shutdown
  no shutdown
  no shutdown
  ft-port vlan 22
  no shutdown
  server 172.18.252.2
  server 172.18.250.2
switch-mode
access-list ALL line 15 extended permit tcp any any
access-list STB line 7 extended permit ip 172.25.248.0 0.0.0.255 10.0.0.0 0.255.255.255
  port 80
probe tcp Traxis_RTSP
  port 554
  description FE1
  probe Traxis_HTTP
  probe Traxis_RTSP
  inservice
  description FE2
  probe Traxis_HTTP
  probe Traxis_RTSP
  inservice
  description FE3
  probe Traxis_HTTP
  probe Traxis_RTSP
  inservice
  description FE4
  probe Traxis_HTTP
  probe Traxis_RTSP
  inservice
  predictor hash address source
  rserver Traxis_FE1
    inservice
  rserver Traxis_FE2
    inservice
  rserver Traxis_FE3
    inservice
  rserver Traxis_FE4
    inservice
sticky ip-netmask 255.255.255.0 address source Sticky_Traxis
  replicate sticky
  serverfarm Traxis
  5 match virtual-address 172.25.255.6 any
  class remote_access
    permit
  class class-default
interface vlan 14
  no shutdown
interface vlan 21
  no shutdown
interface vlan 2000
  no shutdown
  no shutdown
ft peer 1
  heartbeat count 20
ft group 1
  peer 1
  priority 200
  peer priority 150
  inservice
ip route 10.0.0.0 255.0.0.0 172.25.255.1
Hello Peter,
Cheers,
Francesco
