ACE 4710 : how to fix mysql messages on startup
We have an ACE 4710 that are showing the following messages on startup process.
Should we consider these messages as a problem?
How to fix this issue?
INIT: Entering runlevel: 3
Testing PCI path ....
This may take some time, Please wait ....
PCI test loop , count 0
PCI path is ready
Starting services...
Installing MySQL
groupadd: group nobody exists
useradd: user nobody exists
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/data/mysql: time stamp 2008-10-28 17:13:59 is 210510606 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/data/test: time stamp 2008-10-28 17:13:59 is 210510606 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/data: time stamp 2008-10-28 17:13:59 is 210510606 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/scripts/mysql_install_db: time stamp 2008-10-28 17:14:50 is 210510657 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/scripts: time stamp 2008-10-28 17:14:50 is 210510656 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/lib/libmysqlclient_r.so.15: time stamp 2008-10-28 17:10:55 is 210510421 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/share/mysql/swedish: time stamp 2008-10-28 15:21:27 is 210503828 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/share/mysql: time stamp 2008-10-28 17:14:34 is 210510615 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/share/mysql_fix_privilege_tables.sql: time stamp 2008-10-28 14:43:25 is 210501546 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/share/mysql_system_tables.sql: time stamp 2008-10-28 14:39:01 is 210501282 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/share/mysql_system_tables_fix.sql: time stamp 2008-10-28 14:39:01 is 210501282 s in the future
/bin/tar: mysql-enterprise-5.0.66sp1-linux-i686-glibc23-stripped/share: time stamp 2008-10-28 17:14:34 is 210510615 s in the future
MySQL Installed
Installing JRE
JRE Installed
Certificate & key are up to date
Starting sysmgr processes.. Please wait...Done!!!
switch login:
Best regards,
Marcelo Martins de Castro
5 Replies 5
Jorge Bejarano
Level 4
Level 4
Marcelo,
This is not affecting the way how you log in to the unit right? ACE is working as expected correct?
I noticed some software defects which show some similar errors as above.
What version do you run?
Jorge
Mark this if it was useful then other can use it in the future
Jorge,
Yes, the log into the unit is working well.
This asset is not in the environment production.  I was preparing it to replace a damaged unit when I detect this issue and I am worried about to put it to work and it will give me problems after that.
It runs 3.2(6) because it will be a mate in a failover setting.
Marcelo
Marcelo,
Your version is very old!
I was checking our database and this behavior seems to be related with this bug CSCtl05343.
The recommendation is upgrade the software on the ACE to A4(1.1)
Jorge
Jorge,
I'll try your suggestion.
Thanks for help,
Marcelo
Sure!
Jorge
