ACE 4710 Loadbalancer Weblogic Issues
Hi Guys,
Having some issues with my Loadbalancer and weblogic. Eventually i want to SSL Forwarding and everything set up but as of now I can only access the VIP under port 7001 (default weblogic port.) How would i get it so I can access via HTTP. My Config is below.
PA-ACE-4700-SLB/Admin# changeto Prod-Support
PA-ACE-4700-SLB/Prod-Support# show run
Generating configuration....
access-list allow line 8 extended permit ip any any
probe icmp PROBE_SERVICE_ICMP
  interval 5
  passdetect interval 5
  receive 5
probe tcp TCP443_PROBE
  port 443
  interval 5
  receive 5
  connection term forced
  open 2
probe tcp TCP7001_PROBE
  port 7001
  interval 5
  receive 3
  open 2
probe tcp TCP80_PROBE
  interval 5
  receive 3
  open 2
rserver host 228-WLS11host1
  ip address 192.168.211.228
  inservice
rserver host 229-WLS11host2
  ip address 192.168.211.229
  inservice
serverfarm host WLS11-7001
  probe TCP7001_PROBE
  rserver 228-WLS11host1
    inservice
  rserver 228-WLS11host1 7001
  rserver 229-WLS11host2
    inservice
  rserver 229-WLS11host2 7001
sticky http-cookie ACE_COOKIE-7001 7001_STICKY
  cookie insert browser-expire
  replicate sticky
  serverfarm WLS11-7001
class-map type http loadbalance match-any L5
  2 match http url .*
class-map match-all WLS11-7001-CLASS
  2 match virtual-address 192.168.211.50 tcp any
policy-map type loadbalance first-match WLS11-7001-Policy
  class L5
    sticky-serverfarm 7001_STICKY
policy-map multi-match WLS11-SLB
  class WLS11-7001-CLASS
    loadbalance vip inservice
    loadbalance policy WLS11-7001-Policy
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 1000
interface vlan 1000
  ip address 192.168.211.226 255.255.255.0
  access-group input allow
  nat-pool 1 192.168.211.50 192.168.211.50 netmask 255.255.255.255 pat
  service-policy input WLS11-SLB
  no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.211.235
Thanks for any help you can provide.
Hummm,
Andy
1) Can you modify this?
  2 match http url .*
to look like this:
  2 match http url /.*
2)Can you do this:
  probe TCP7001_PROBE
  inservice
  inservice
3)Can you clear all the browser´s cookies and/or open a new browser window? It might be possible that some clients are stuck to the servers with does not have hardcoded the port.
4)Can you do:  clear stats loadbalance?(won´t affect anything)
5)Then generate traffic
6)Then get:
#show service-policy WLS11-SLB class-map WLS11-7001-CLASS detail
#show stat http
Jorge
5 Replies 5
Jorge Bejarano
Level 4
Level 4
Andrew,
Why do you get some of the services disabled?
  probe TCP7001_PROBE
    inservice
    inservice
Did you try something like this already?
  probe TCP7001_PROBE
  inservice
  inservice
What is the status in the probe? Is it failing?
Jorge
Probes are successful and the app is loadbalancing the way it should with Sticky Sessions however i want to be able to hit the vip on port 80 rather than 7001. If i goto 192.168.211.50:7001 it works great if i go to http://192.168.211.50 i got nothing.
Let me know if you have any ideas.
Thanks!
-Andy
Hummm,
Andy
  2 match http url .*
to look like this:
2)Can you do this:
  probe TCP7001_PROBE
  inservice
  inservice
6)Then get:
#show stat http
Jorge
You nailed it Jorge. Thanks for your help. I am going to work on the Daunting task of setting up SSL now.
-Andy
Sounds good!
Good Luck
Jorge
