ace 4710 monitoring compression and SSL throughput in nagios
eagles0513875
Hey guys I have been given a task to create 2 checks using snmp for nagios. I am googling left right and center to maybe try and find the appropriate OID's that i can pass to this nagios check for both ssl throughput as well as compression throughput.
Any help would be greatly appreciated
chrhiggi
Level 3
Level 3
Jonathan-
ciscoL4L7moduleResourceLimitMIB
DESCRIPTION
        sslConnections     (9)  <-- Here
        mgmtBandwidth      (10)
        throughput         (11)
        missedMac          (12)
        httpCompression    (13)   <-- Here
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-L4L7MODULE-RESOURCE-LIMIT-MIB.my
The numbers aren't throughput, they are a rate CPS.  We don't keep track of packet size in relation to speed for those counters specifically.  "throughput  (11)" relates to the entire context minus management bandwidth.
Chris
What would I pass to the nagios check in regards to OID?
I have no idea how your tool works, but 1.3.6.1.4.1.9.9.480.1.1.4.1.6 is the OID if you walk it.
