ACE balancing problems
p.diaz
Level 2
Level 2
Hi everyone.
We have a customer who has a server farm formed by 3 servers with the following real ip address:
10.10.24.5-6-7  and a virtual 10.10.24.3 as configured in the ace module.
We found the following behavior in the session number of the servers. We can conclude that there is a server with much more sessions than the others (10.10.24.6):
Can sombody help me telling why can happen that?
I am attaching the ACE config as a reference
ACE-DIGENERAL/OCS# sh serverfarm Herramientas_Col
serverfarm     : Herramientas_Col, type: HOST
total rservers : 3
                                                ----------connections-----------
       real                  weight state        current    total
   rserver: SP1
       10.10.24.5:0          8      OPERATIONAL  390         296043280
   rserver: SP2
       10.10.24.6:0          8      OPERATIONAL  1003        3371471400
   rserver: SP3
       10.10.24.7:0          8      OPERATIONAL  354         164816790
Como se puede observar el sever 10.10.24.6 posee mas del doble de conexiones que los otros 2.
5.       En el siguiente pantallazo también se observan conexiones detalladas y los puertos por donde habla:
ACE-DIGENERAL/OCS# sh conn serverfarm Herramientas_Col
conn-id    np dir proto vlan source                destination           state
70         1  in  TCP   951  10.10.22.13:3837      10.10.24.3:80         ESTAB
17239      1  out TCP   324  10.10.24.7:80         10.10.22.13:3837      ESTAB
76         1  in  TCP   951  10.83.21.32:1419      10.10.24.3:80         ESTAB
5531       1  out TCP   324  10.10.24.6:80         10.83.21.32:1419      ESTAB
95         1  in  TCP   951  10.20.7.51:1702       10.10.24.3:80         ESTAB
16237      1  out TCP   324  10.10.24.6:80         10.20.7.51:1702       ESTAB
98         1  in  TCP   951  10.80.31.55:3188      10.10.24.3:80         ESTAB
11995      1  out TCP   324  10.10.24.6:80         10.80.31.55:3188      ESTAB
32749      1  in  TCP   951  10.80.21.23:1926      10.10.24.3:80         ESTAB
108        1  out TCP   324  10.10.24.7:80         10.80.21.23:1926      ESTAB
110        1  in  TCP   951  10.25.14.231:1705     10.10.24.3:80         ESTAB
37994      1  out TCP   324  10.10.24.6:80         10.25.14.231:1705     ESTAB
7438       1  in  TCP   951  10.31.102.32:2329     10.10.24.3:80         ESTAB
141        1  out TCP   324  10.10.24.7:80         10.31.102.32:2329     ESTAB
31247      1  in  TCP   951  10.81.36.32:1650      10.10.24.3:80         ESTAB
151        1  out TCP   324  10.10.24.5:80         10.81.36.32:1650      ESTAB
176        1  in  TCP   951  10.20.208.124:2598    10.10.24.3:80         ESTAB
13219      1  out TCP   324  10.10.24.7:80         10.20.208.124:2598    ESTAB
32576      1  in  TCP   951  10.233.9.40:1577      10.10.24.3:80         ESTAB
233        1  out TCP   324  10.10.24.6:80         10.233.9.40:1577      ESTAB
27499      1  in  TCP   951  10.218.16.28:2902     10.10.24.3:80         ESTAB
244        1  out TCP   324  10.10.24.5:80         10.218.16.28:2902     ESTAB
248        1  in  TCP   951  10.85.19.55:1540      10.10.24.3:80         ESTAB
14014      1  out TCP   324  10.10.24.7:80         10.85.19.55:1540      ESTAB
27166      1  in  TCP   951  10.25.22.90:1766      10.10.24.3:80         ESTAB
254        1  out TCP   324  10.10.24.6:80         10.25.22.90:1766      ESTAB
380        1  in  TCP   951  10.23.22.62:1855      10.10.24.3:80         ESTAB
11563      1  out TCP   324  10.10.24.6:80         10.23.22.62:1855      ESTAB
397        1  in  TCP   951  10.212.35.30:1540     10.10.24.3:80         ESTAB
15491      1  out TCP   324  10.10.24.7:80         10.212.35.30:1540     ESTAB
35588      1  in  TCP   951  10.100.30.5:1773      10.10.24.3:80         ESTAB
405        1  out TCP   324  10.10.24.6:80         10.100.30.5:1773      ESTAB
31392      1  in  TCP   951  10.216.27.41:1524     10.10.24.3:80         ESTAB
449        1  out TCP   324  10.10.24.6:80         10.216.27.41:1524     ESTAB
592        1  in  TCP   951  10.25.21.219:1364     10.10.24.3:80         ESTAB
2988       1  out TCP   324  10.10.24.5:80         10.25.21.219:1364     ESTAB
614        1  in  TCP   951  10.25.42.221:1517     10.10.24.3:80         ESTAB
18877      1  out TCP   324  10.10.24.6:80         10.25.42.221:1517     ESTAB
21553      1  in  TCP   951  10.80.39.123:1634     10.10.24.3:80         ESTAB
652        1  out TCP   324  10.10.24.6:80         10.80.39.123:1634     ESTAB
13640      1  in  TCP   951  10.206.2.34:1385      10.10.24.3:80         ESTAB
708        1  out TCP   324  10.10.24.6:80         10.206.2.34:1385      ESTAB
26959      1  in  TCP   951  10.100.30.7:1289      10.10.24.3:80         ESTAB
719        1  out TCP   324  10.10.24.5:80         10.100.30.7:1289      ESTAB
29277      1  in  TCP   951  10.100.202.50:1248    10.10.24.3:80         ESTAB
758        1  out TCP   324  10.10.24.5:80         10.100.202.50:1248    ESTAB
6185       1  in  TCP   951  10.25.27.222:1497     10.10.24.3:80         ESTAB
760        1  out TCP   324  10.10.24.6:80         10.25.27.222:1497     ESTAB
767        1  in  TCP   951  10.97.21.28:1821      10.10.24.3:80         ESTAB
23511      1  out TCP   324  10.10.24.7:80         10.97.21.28:1821      ESTAB
826        1  in  TCP   951  10.31.105.140:3810    10.10.24.3:80         ESTAB
13460      1  out TCP   324  10.10.24.6:80         10.31.105.140:3810    ESTAB
21987      1  in  TCP   951  10.25.31.213:1855     10.10.24.3:80         ESTAB
839        1  out TCP   324  10.10.24.5:80         10.25.31.213:1855     ESTAB
874        1  in  TCP   951  10.88.29.27:1503      10.10.24.3:80         ESTAB
29839      1  out TCP   324  10.10.24.6:80         10.88.29.27:1503      ESTAB
945        1  in  TCP   951  10.27.122.13:1286     10.10.24.3:80         ESTAB
32298      1  out TCP   324  10.10.24.6:80         10.27.122.13:1286     ESTAB
24330      1  in  TCP   951  10.40.21.50:2368      10.10.24.3:80         ESTAB
954        1  out TCP   324  10.10.24.6:80         10.40.21.50:2368      ESTAB
961        1  in  TCP   951  10.80.26.76:1414      10.10.24.3:80         ESTAB
11176      1  out TCP   324  10.10.24.5:80         10.80.26.76:1414      ESTAB
28989      1  in  TCP   951  10.91.22.38:1408      10.10.24.3:80         ESTAB
985        1  out TCP   324  10.10.24.5:80         10.91.22.38:1408      ESTAB
1006       1  in  TCP   951  10.217.4.20:1522      10.10.24.3:80         ESTAB
26946      1  out TCP   324  10.10.24.5:80         10.217.4.20:1522      ESTAB
8360       1  in  TCP   951  10.11.3.28:1679       10.10.24.3:80         ESTAB
1020       1  out TCP   324  10.10.24.6:80         10.11.3.28:1679       ESTAB
9498       1  in  TCP   951  10.25.42.221:1519     10.10.24.3:80         ESTAB
1031       1  out TCP   324  10.10.24.6:80         10.25.42.221:1519     ESTAB
18510      1  in  TCP   951  10.165.55.51:1232     10.10.24.3:80         ESTAB
1072       1  out TCP   324  10.10.24.7:80         10.165.55.51:1232     ESTAB
5583       1  in  TCP   951  10.25.14.12:2086      10.10.24.3:80         ESTAB
1142       1  out TCP   324  10.10.24.6:80         10.25.14.12:2086      ESTAB
39713      1  in  TCP   951  10.25.36.58:1663      10.10.24.3:80         ESTAB
1144       1  out TCP   324  10.10.24.7:80         10.25.36.58:1663      ESTAB
8601       1  in  TCP   951  10.217.26.34:1677     10.10.24.3:80         ESTAB
1167       1  out TCP   324  10.10.24.6:80         10.217.26.34:1677     ESTAB
17209      1  in  TCP   951  10.165.40.45:1526     10.10.24.3:80         ESTAB
1173       1  out TCP   324  10.10.24.5:80         10.165.40.45:1526     ESTAB
18708      1  in  TCP   951  10.31.105.137:3714    10.10.24.3:80         ESTAB
1175       1  out TCP   324  10.10.24.6:80         10.31.105.137:3714    ESTAB
1180       1  in  TCP   951  10.201.18.40:4777     10.10.24.3:80         ESTAB
6528       1  out TCP   324  10.10.24.6:80         10.201.18.40:4777     ESTAB
1214       1  in  TCP   951  10.31.104.46:1501     10.10.24.3:80         ESTAB
5924       1  out TCP   324  10.10.24.6:80         10.31.104.46:1501     ESTAB
1228       1  in  TCP   951  10.231.37.32:1161     10.10.24.3:80         ESTAB
15171      1  out TCP   324  10.10.24.6:80         10.231.37.32:1161     ESTAB
28431      1  in  TCP   951  10.25.5.76:2317       10.10.24.3:80         ESTAB
1293       1  out TCP   324  10.10.24.5:80         10.25.5.76:2317       ESTAB
1328       1  in  TCP   951  10.201.2.26:1293      10.10.24.3:80         ESTAB
19276      1  out TCP   324  10.10.24.7:80         10.201.2.26:1293      ESTAB
1356       1  in  TCP   951  10.80.23.27:1396      10.10.24.3:80         ESTAB
4141       1  out TCP   324  10.10.24.6:80         10.80.23.27:1396      ESTAB
1368       1  in  TCP   951  10.80.36.124:1428     10.10.24.3:80         ESTAB
19905      1  out TCP   324  10.10.24.6:80         10.80.36.124:1428     ESTAB
30280      1  in  TCP   951  10.25.8.11:4836       10.10.24.3:80         ESTAB
1438       1  out TCP   324  10.10.24.6:80         10.25.8.11:4836       ESTAB
1478       1  in  TCP   951  10.216.6.46:4153      10.10.24.3:80         ESTAB
12312      1  out TCP   324  10.10.24.6:80         10.216.6.46:4153      ESTAB
23389      1  in  TCP   951  10.211.30.38:1593     10.10.24.3:80         ESTAB
1527       1  out TCP   324  10.10.24.6:80         10.211.30.38:1593     ESTAB
1562       1  in  TCP   951  10.90.21.58:2889      10.10.24.3:80         ESTAB
36398      1  out TCP   324  10.10.24.7:80         10.90.21.58:2889      ESTAB
1587       1  in  TCP   951  10.84.22.29:2121      10.10.24.3:80         ESTAB
37031      1  out TCP   324  10.10.24.6:80         10.84.22.29:2121      ESTAB
1624       1  in  TCP   951  10.25.21.218:1465     10.10.24.3:80         ESTAB
4941       1  out TCP   324  10.10.24.6:80         10.25.21.218:1465     ESTAB
Nelson Galimba
I see you have not gotten any replies to this post.  Please try  moving this post  to content networking.  If moving it does not work ( I did not have permissions to move it), try re-posting it in content networking.
Nelson
chrhiggi
Level 8
Level 8
Hello!
A "show connection serverfarm Herramientas_Col detail"  and "show sticky database group POOL3" would be handy in this situation.  You have sticky configured which will intentionally throw off the loadbalancing predictor.  My guess at this point is that rserver SP2 might not close connections in the same manner that SP1 and SP3 do.  If that was true, that would result in a longer connection time, which means the sticky database would not idle out as fast, hence more connection for SP2.
Chris
