el 11-10-2011 08:49 AM
I've got a config working to accommodate the required use of reverse proxy servers infront of my application servers. Traffic comes into the Front ACE and I insert a header "SRCIP" with the original client IP address which is preserved through the Rev Proxy servers and is then inspected on the Back ACE to create a sticky to a given application server/SRCIP pairing. The use of the RP's appears to require using the persistence-rebalance option otherwise the traffic get stuck to the wrong app server. The app functions perfectly with this config; however, there is a severe performance impact. Using load-runner, we see response times go from 1.5 seconds to 16 seconds for the same transactions comparing this config to a previous config which used static sticky to bind the RP to the app servers..
Question: Is there a better way to do this and remain dynamic, or some way to optimize this approach to reduce the performance impact.
Relevant Config for both ACE's here:
!!Front ACE
parameter-map type http HTTP_REBAL
length-exceed continue
sticky ip-netmask 255.255.255.255 address source ALPHA-SRCIP-sticky
timeout 60
replicate sticky
serverfarm ALPHA
policy-map type loadbalance first-match vip-R1A-ALPHA
class class-default
sticky-serverfarm ALPHA-SRCIP-sticky
insert-http SRCIP header-value "%is"
policy-map multi-match PREP-VIP
class VIP-ALPHA-R1A
loadbalance vip inservice
loadbalance policy vip-R1A-ALPHA
appl-parameter http advanced-options HTTP_REBAL
ssl-proxy server SSL_ALPHA_R1A
!!Back ACE
sticky http-header SRCIP ALPHA-SRCIP-sticky
timeout 60
replicate sticky
serverfarm coresoms-ALPHAfarm
class-map type http loadbalance match-all SRCIP-MAP
2 match http header SRCIP header-value ".*"
policy-map type loadbalance first-match vip-lb-ALPHA
class SRCIP-MAP
policy-map multi-match lb-vip
class VIP-ALPHA
loadbalance policy vip-lb-ALPHA
¡Resuelto! Ir a solución.
el 11-11-2011 03:15 AM
Hi Joseph,
To achieve this you need to do stickiness based on some L7 parameter (either the header you are currently using or some cookie), so, whatever you do you will have to use persistence rebalance.
I have one possible theory for your issue.
The ACE has two different ways of treating the L7 connections internally, that we call "proxied" and "unproxied". In essence, the proxied mode means that the traffic will be processed by one of the CPU (normally to inspect/modify the L7 data), while, on the unproxied mode, the ACE sets up a hardware shortcut that allows forwarding traffic without the need to do any processing on it.
For a L7 connection, the ACE will proxy it at the beginning, and, once all the L7 processing has been done it will unproxy the connection to save resources. Before it goes ahead with the unproxying, it needs to see the ACK for the last L7 data sent. This wait, on a Internet environment can introduce around 100-200ms of delay for each HTTP request, which can end up adding into a very big delay. By default, if the ACE sees that the RTT to the client is more than 200ms, the connection will never be unproxied to avoid these delays, so I think we could fix your issue by tweaking this threshold.
From what you described, I asssume you don't have many connections (because they all come through a proxy) and that the connections will have a lot of HTTP requests inside. With that in mind, I would suggest setting the threshold to 0 to ensure to keep connections always proxied. To do this, you would nee to configure a parameter map like the one below and add it to your VIP
parameter-map type connectionset tcp wan-optimization rtt 0
Even though this setting may avoid your issue, it also has some drawbacks. The main one is that the ACE20 only supports up to 512K simultaneous L7 connections in proxied state (which includes also the connections towards the servers, so, it would be 250K for client connections), so, if the amount of simultaneous connections reaches that limit, new connections would be dropped. The second issue, although not so impacting, would be that the maximum number of connections per second supported would also go down slightly due to the increased processing needed.
I hope this helps
Daniel
el 11-10-2011 02:33 PM
Anyone?
Hi Joseph,
I hope this helps
Daniel
el 11-14-2011 12:51 PM
Thanks - going to try this now. I'll post results shortly.
el 11-14-2011 03:43 PM
Looks like this helped greatly. The response time went from 16 seconds down to about 4. It's still higher then the original config, but a lot closer. I'm going to try and put that same config into the front ACE to see if it further improves.
Thanks !
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
