ACE best practice for proxy servers
pemalcoun
Frequent Visitor
Frequent Visitor
Dear,
I would like to know which is the best practice scenario to load balance proxy servers:
1- Best practice to have transparent proxy or proxy setting on the web browser?
2- for transparent proxy: best practice to use ip wccp or route-map pointing to the ACE VIP?
3- What are the advantages and disadvantages of transparent proxy V/S web browser proxy setting.
Pierre
sivaksiv
It depends on your requirement. The one advantage of using using PBR - would provide the flexibility of only directing traffic which needs to be load balanced to cache servers and dont need to send all traffic to ACE.
Guide: Transparent caching using ACE
http://wwwin.cisco.com/dss/adbu/collateral/ACE_Transparent_Caching.pdf
Siva
Thank you for your reply and clarification.
Appreciate sharing the link again, it's not working.
Thanks & Regards,
Pierre
Sorry, that seem to be an internal link.
You can also check the below post where a sample config is posted here for transparent cache.
https://supportforums.cisco.com/thread/129106
               Best practice :
VIP would be a catch all address.
To optimize the caching predictor hash url is used.
You can also use mac-sticky on interface so proper flow persistence is used within ACE
The mode is transparent so we preserve the destination ip address.
Siva
Hi Siva,
Thank you for your support.
Best regards,
Pierre
