ACE - Class-maps
meckel
Community Member
I want to load balance traffic to a VIP based on client source address. Here is what I had in mind:
access-list special-25 extended permit tcp host 10.20.138.18 host 10.20.96.19 eq 25
access-list special-25 extended permit tcp host 10.20.138.30 host 10.20.96.19 eq 25
access-list special-25 extended permit tcp host 10.20.138.40 host 10.20.96.19 eq 25
access-list special-25 extended permit tcp host 10.20.254.88 host 10.20.96.19 eq 25
access-list internal-25 extended permit tcp 10.20.0.0 0.0.255.255 host 10.20.96.19 eq 25
access-list internet-25 extended permit tcp any host 10.20.96.19 eq 25
class-map match-any INTERNET-MAIL
2 match access-list internet-25
class-map match-any INTERNAL-MAIL
2 match access-list internal-25
class-map match-any SPECIAL-MAIL
2 match access-list special-25
class-map match-all VIP-MAILGATE-25
description MAILGATE INTERNAL 25
2 match virtual-address 10.20.96.19 tcp eq 25
serverfarm host mailgate-zero
description INTERNET MAIL
failaction purge
rserver mailgate-1
rserver mailgate-2
rserver mailgate-3
rserver mailgate-4
serverfarm host mailgate-one
description INTERNAL MAIL
failaction purge
rserver mailgate-5
rserver mailgate-6
serverfarm host mailgate-two
description I DON'T KNOW MAIL
failaction purge
rserver mailgate-8
policy-map type loadbalance first-match MAILGATE-POLICY
class SPECIAL-MAIL
serverfarm mailgate-two
class INTERNAL-MAIL
serverfarm mailgate-one
class INTERNET-MAIL
serverfarm mailgate-zero
policy-map multi-match CLIENT-VIPS
class VIP-MAILGATE-25
loadbalance vip inservice
loadbalance policy MAILGATE-POLICY
loadbalance vip icmp-reply active
The problem with this design is the policy-map MAILGATE-POLICY won't accept anything but the "class-default".
Any ideas how can I make this work?
Milo
Gilles Dufour
Milo,
you need to create a class-map of type http.
Sounds weird but this is the way to do it.
You can then match using a 'match source-address' command.
You can't specify the destination with an acl, but this traffic would normal hit a vip anyway this will set the destination.
Gilles.
Gilles Dufour
Milo,
Gilles.
Gilles,
You're right, it does sound weird. However, it appears to work (the commands weren't rejected anyway). Now as soon as I get time on the real servers I test it out. Here's my modified config with your suggestion:
class-map type http loadbalance match-all INTERNAL-MAIL-TEST
10 match source-address 10.20.0.0 0.0.255.255
class-map type http loadbalance match-any SPECIAL-MAIL-TEST
10 match source-address 10.20.138.18 255.255.255.255
15 match source-address 10.20.138.30 255.255.255.255
20 match source-address 10.20.138.40 255.255.255.255
25 match source-address 10.20.254.88 255.255.255.255
class-map match-all VIP-MAILGATE-TEST-25
description MAILGATE-TEST.NAU.EDU SMTP MAIL
2 match virtual-address 10.20.96.36 tcp eq smtp
policy-map type loadbalance first-match MAILGATE-POLICY-TEST
class SPECIAL-MAIL-TEST
serverfarm mailgate-two-test
class INTERNAL-MAIL-TEST
serverfarm mailgate-one-test
class class-default
serverfarm mailgate-zero-test
class VIP-MAILGATE-TEST-25
loadbalance policy MAILGATE-POLICY-TEST
Thank you!
Milo
