ACE Compression Errors
ian.richards
Community Member
I have a ACE 4710 which I have enabled compression on the L7 policy map using compress default-method gzip. We have recently run a performance test and I have noticed many compression errors on the show service-policy detail output. However I cannot find details as to what these errors are or cause in any manual.
The comprssion specific stats from show service-policy detail are:
      compression:
        bytes_in  : 14449218178                bytes_out : 6622221458
        Compression ratio : 54.16%
                Gzip: 2308157         Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 1244            Content type       : 160821
        Not HTTP 1.1: 39              HTTP response error: 1935746
        Others      : 0
If I am reading this correctly 90% of compression hits where in error?
Can anyone point me at the correct documentation to find out what is going on?
ian.richards
Community Member
Is it possible the HTTP Response errors are due to HTTP 304 responses?
