ACE Configuration Issue.
syjeon
We would like to configure on ace like below:
the virtual ip address and port like this
: 10.10.10.10:8000,this ip address will be use to outside user request servie
and we have to configure server farm like below
real server 10.10.10.1:8001, 10.10.10.1:8002, 10.10.10.1:8003 ...
the ip address is same on 10.10.10.10:8000's serverfarm, but real server service is different, and this port should be loadbalanced and healchecked.
Is it possible solution? F5 big ip , Nortal is possible, but I don't know on ACE above issue.
If you ok. could you give me a sample configuration?
5 Replies 5
Gilles Dufour
rserver Server1
ip address 10.10.10.1
inservice
serverfarm Farm1
rserver Server1 8001
inservice
rserver Server1 8002
inservice
rserver Server1 8003
inservice
class-map MyVip
match virtual 10.10.10.10 tcp eq 8000
policy type loadbalance http first MyPolicy
class class-default
serverfarm Farm1
policy multimatch SLB
class MyVip
load policy MyPolicy
load vip inservice
interface vlan X
service in SLB
Gilles.
HI Dear
1. create probe
2. create rservers
3. create serverfarms
( inside serverfarm add as follows:
1. add rservers with port
inservice
2. add probe)
4. create class-maps(for the traffic of your interest on which you want to put some action like forward/drop/loadbalance or something else)
5. create policy-maps(for taking some action on class mapps)
(do inside following in policy maps:
1. add class maps
2. loadbalance vip
3. nat rules
etc)
6. create interface
7. create service-policy (so that you can apply these policy maps on particular interfaces for traafic of that class for filtering or the action specifiedd in the policy maps).
for healthcheck you need to create a proble something like this as follows:
probe http HTTP_Probe
port 8000
interval 2
passdetect interval 15
and then include this into serverfarm as follows:
serverfarm Farm1
probe HTTP_Probe
inservice
inservice
inservice
Kindly find some config sample on continued page..
continue to page 2.....
page 2....
Also i forget to tell you to
8.create resourse-class
9. create context othr then admin context if you need multiple contexts:
(inside context add resource class)
10 class map type management (for remote access)
as follows:
Kindly find some config sample as follows:
ACE/Admin# sh run
Generating configuration....
resource-class ABCD_Resource
limit-resource all minimum 5.00 maximum unlimited
limit-resource sticky minimum 5.00 maximum unlimited
boot system image:c4710ace-mz.A3_2_1.bin
hostname ACE
context Admin
member ABCD_Resource
access-list everyone line 10 extended permit icmp any any
access-list everyone line 20 extended permit ip any any
access-list for-cap line 8 extended permit ip any any
probe http HTTP-Probe
port 8000
interval 2
faildetect 2
request method head
probe icmp ICMP-Probe
interval 2
faildetect 2
passdetect interval 60
probe tcp TCP-8000
port 8000
interval 2
faildetect 2
passdetect count 2
open 1
rserver host A
inservice
rserver host B
ip address 10.10.10.2
inservice
rserver host C
ip address 10.10.10.3
inservice
rserver host D
ip address 10.10.10.4
inservice
serverfarm host SF-8000-1
probe ICMP-Probe
probe TCP-8000
rserver A 8000
inservice
rserver B 8000
inservice
serverfarm host SF-8000-2
probe HTTP-Probe
probe ICMP-Probe
probe TCP-8000
rserver C 8000
inservice
rserver D 8000
inservice
class-map match-all L4-CLASS-REDIRECT-1
2 match virtual-address 10.10.60.10 tcp eq www
class-map match-all VIP-PORT-8000-1
2 match virtual-address 10.10.60.10 tcp eq https
class-map match-all VIP-PORT-8000-2
2 match virtual-address 10.10.60.12 tcp eq https
class-map type management match-any remote-mgmt
10 match protocol ssh any
20 match protocol telnet any
30 match protocol icmp any
40 match protocol http any
50 match protocol https any
class-map match-any server-initiated
3 match source-address 10.10.10.4 255.255.255.255
4 match source-address 10.10.10.3 255.255.255.255
policy-map type management first-match remote-access
class remote-mgmt
permit
policy-map type loadbalance first-match VIP-POLICY-8000-1
class class-default
policy-map multi-match Service-Policy-8000-1
class VIP-PORT-8000-1
loadbalance vip inservice
loadbalance policy VIP-POLICY-8000-1
loadbalance vip icmp-reply
nat dynamic 1 vlan 60
class L4-CLASS-REDIRECT-1
policy-map multi-match Service-Policy-8000-2
class VIP-PORT-8000-2
loadbalance policy VIP-POLICY-8000-2
ssl-proxy server SSL-Offload-Proxy-2
policy-map multi-match server-side
class server-initiated
interface vlan 10
description APPPROD-Client-Vlan
bridge-group 10
mtu 1500
access-group input everyone
access-group output everyone
service-policy input remote-access
no shutdown
interface vlan 30
description management-vlan-interface
ip address 10.10.30.22 255.255.255.0
no shutdown
continued page 3......
page 3........
interface vlan 60
description One-arm VLAN
ip address 10.10.60.1 255.255.255.0
nat-pool 1 10.10.60.3 10.10.60.3 netmask 255.255.255.0 pat
service-policy input Service-Policy-8000-1
service-policy input Service-Policy-8000-2
service-policy input server-side
no shutdown
interface vlan 100
description APPPROD-Server-Vlan
bridge-group 10
no shutdown
kindly rate if you find it any useful to you else no issue.
kind regards
sachin
some sample config examples and guides find on below links which are like jewel pages to any one:
continued page 4.....
page 4....
just for you dear:
1.ACE Client and Servers Hitting the Same VIP
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c6ef5.shtml
2. Configure ACE in Routed Mode with L7 Policies
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3048.shtml
3. Configure ACE Module for End to End SSL Termination
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c6f37.shtml
4. Configure ACE with Source NAT and Client IP Header Insert
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3041.shtml
5. Configure ACE with SSL Termination and URL Rewrite
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3045.shtml
6. Integrate Cisco Service Modules with Cisco Catalyst 6500 Virtual Switching System 1440
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c72b.shtml
7. Product support page for ace module 47xx
http://www.cisco.com/en/US/products/ps6906/tsd_products_support_model_home.html
8. Cisco ACE 4700 Series Appliance Device Manager GUI Configuration Guide
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/device_manager/guide/dmguigd.html
9. Cisco ACE appliance product home page
http://www.cisco.com/en/US/products/ps7027/tsd_products_support_series_home.html
10. Cisco ace config ssample :
http://snippets101.blogspot.com/search/label/ace
1. FTP serverfarm on Cisco ACE
http://snippets101.blogspot.com/2007/06/ftp-serverfarm-on-cisco-ace.html
11. CISCO ACE with SAP
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/prod_white_paper0900aecd80653362.pdf
12. CISCO ACE white papaers with tons of code and design examples
Please rate if you find it any useful for you.
Kind regards
keep in touch.
sachin garg
