ACE configuration using GUI
chandru.j
Level 3
Level 3
Hi all,
i configured ACE in multi context for failover. then i configured primary ACE using GUI after configuring server farm and click DM sync and SYNC all.Then i checked secondary ACE whether configuration is synced but its not sync with secondary.what might be the problem.
Gilles Dufour
do a 'show ft group detail' and make sure you have config synch enabled
"Running cfg sync enabled : Enabled"
If not, you need to turn it on.
Also check the status.
"Running cfg sync status "
Sometimes it is enabled but not working because files can't be synched like ssl keys/certs or script probes.
Gilles.
