ACE context management per user
Emre Ozkan
Dear All,
Can per user get management access in per context on ACE module?
For instance, user A can manage just context A, user B can manage just context B on attachment file.
Thanks.
Marko Leopold
Level 6
Level 6
If you use an ACS for TACACS you can (for ACE you have to) set custom attributes for your group. The attributes look like this:
shell:= ...
If you want to restrict the user from changing into another context, you should change the Shell Command Authorization Set settings.
i will try your suggestion, thank you for your reply.
