ACE error: Maximum 10 http header map is allowed per policy
net-harry
Level 2
Level 2
I get the error above when I try to add additional sticky serverfarms to a policy map on our ACE 4710s:
sticky http-cookie ACE-PROJECT1 PROJECT1-SERVERFARM-STICKY
cookie insert browser-expire
timeout 60
serverfarm PROJECT1-SERVERFARM
sticky http-cookie ACE-PROJECT2 PROJECT2-SERVERFARM-STICKY
timeout 60
serverfarm PROJECT2-SERVERFARM
sticky http-cookie ACE-PROJECT3 PROJECT3-SERVERFARM-STICKY
timeout 60
serverfarm PROJECT3-SERVERFARM
sticky http-cookie ACE-PROJECT4 PROJECT4-SERVERFARM-STICKY
timeout 60
serverfarm PROJECT4-SERVERFARM
sticky http-cookie ACE-PROJECT5 PROJECT5-SERVERFARM-STICKY
timeout 60
serverfarm PROJECT5-SERVERFARM
sticky http-cookie ACE-PROJECT6 PROJECT6-SERVERFARM-STICKY
timeout 60
serverfarm PROJECT6-SERVERFARM
sticky http-cookie ACE-PROJECT7 PROJECT7-SERVERFARM-STICKY
timeout 60
serverfarm PROJECT7-SERVERFARM
class-map match-all PROJECT-NONPROD-CLASS
2 match virtual-address x.x.x.x tcp eq https
class-map match-all PROJECT-NONPROD-CLASS-REDIRECT
2 match virtual-address x.x.x.x tcp eq www
class-map type http loadbalance match-all PROJECT4-HOST-HEADER-CLASS
2 match http header Host header-value "PROJECT4.examples.com"
class-map type http loadbalance match-all PROJECT5-HOST-HEADER-CLASS
2 match http header Host header-value "PROJECT5.examples.com"
class-map type http loadbalance match-all PROJECT6-HOST-HEADER-CLASS
2 match http header Host header-value "PROJECT6.examples.com"
class-map type http loadbalance match-all PROJECT1-HOST-HEADER-CLASS
2 match http header Host header-value "PROJECT1.examples.com"
class-map type http loadbalance match-all PROJECT2-HOST-HEADER-CLASS
2 match http header Host header-value "PROJECT2.examples.com"
class-map type http loadbalance match-all PROJECT3-HOST-HEADER-CLASS
2 match http header Host header-value "PROJECT3.examples.com"
class-map type http loadbalance match-all PROJECT7-HOST-HEADER-CLASS
2 match http header Host header-value "PROJECT7.examples.com"
policy-map type loadbalance first-match PROJECT-NONPROD-LOADBALANCE-POLICY
class PROJECT1-HOST-HEADER-CLASS
sticky-serverfarm PROJECT1-SERVERFARM-STICKY
class PROJECT2-HOST-HEADER-CLASS
sticky-serverfarm PROJECT2-SERVERFARM-STICKY
class PROJECT3-HOST-HEADER-CLASS
sticky-serverfarm PROJECT3-SERVERFARM-STICKY
class PROJECT4-HOST-HEADER-CLASS
sticky-serverfarm PROJECT4-SERVERFARM-STICKY
class PROJECT5-HOST-HEADER-CLASS
sticky-serverfarm PROJECT5-SERVERFARM-STICKY
class PROJECT6-HOST-HEADER-CLASS
sticky-serverfarm PROJECT6-SERVERFARM-STICKY
class class-default
drop
ACE1/PROJECT-CONTEXT# conf t
ACE1/PROJECT-CONTEXT(config)# policy-map type loadbalance first-match PROJECT-NONPROD-LOADBALANCE-POLICY
ACE1/PROJECT-CONTEXT(config-pmap-lb)# class PROJECT7-HOST-HEADER-CLASS
ACE1/PROJECT-CONTEXT(config-pmap-lb-c)# sticky-serverfarm PROJECT7-SERVERFARM-STICKY
Error: Maximum 10 http header map is allowed per policy
ACE1/PROJECT-CONTEXT(config-pmap-lb-c)# serverfarm PROJECT7-SERVERFARM
As you can se above I am allowed to add another non-sticky serverfarm, but not a sticky which is what I would like to do.
I searched for the error and came up with bug CSCsr28182, but that does not really seem to apply in my case since I do not have 10 http header map statements.
Does anyone have any idea why I get this error message?
We are running version A3(2.3).
Best regards,
Harry
Gilles Dufour
Actually it is not just header-map.
It is 10 regular expression.
Each header-map consume 1 regexp.
Each sticky cookie consume also 1 regexp.
So, you have hit the limit.
Try to combine header-maps.
Gilles.
Hi again,
Thanks for the answer!
I still do not quite understand how it works with the limit of 10 regular expressions.
In my configuration I have 7 header maps and I am allowed to enter 6 sticky maps, but not 7. It seems in that case like 13 regexs are allowed, but not 14?
Are there any plans for increasing the number of allowed regular expressions in future releases?
Best regards,
Harry
I was able to install your config on my device running A3(2.2).
switch/Ispace(config-pmap-lb-c)# do sho run policy-map | be PROJECT-NONPROD-LOADBALANCE-POLICY
Generating configuration....
class class-default
drop
You should probably open a service request so we can look at the complete config.
Gilles.
