ACE FT Link Max Latency
markw-redstone
Frequent Visitor
Frequent Visitor
Does anyone know what the maximum acceptable latency is on a FT Link between a Pair of ACE30 modules configured as a FT Pair with multiple contexts running active/active.
I am trying to ascertain if it is possible to site in different DC's seperated by 100's of kilometres accross a 10Gb circuit.
I am unable to find anything in any of the avaiilable documentation.
Thanks in advance.
Mark
Surya ARBY
Level 10
Level 10
No problem with network oriented redundancy. Latency is only a very sensitive parameter when using application cluster (when you have R/W on shared storage).
It will just increase a little bit the failure detection time. However, beware if you use stateful sync of stickyness and stuff like that.
