ACE - Generic loadbalance by TCP Port?
b-cunningham
I am using an ACE 4710 load balancer to balance generic TCP traffic between two servers using source IP address.  I find that I now have a situation where I have different connections (TCP ports 20073, 20071 and 20025) coming in from the same source address.  I need to move the one connection on port 20073 to the RealTime host and leave the rest going to the Tandem.  I can’t seem to come up with a class map or policy map that will work with what I already have.  Any ideas….?
rserver host Realtime1
  description Realtime1
  ip address 10.1.2.12
  conn-limit max 4000000 min 4000000
  probe ECHO_PROBE
  inservice
rserver host Tandem
  description Tandem
  ip address 10.1.2.8
  probe ECHO_PROBE
  inservice
serverfarm host RealTime
  predictor leastconns slowstart 120
  rserver Realtime1
    inservice
serverfarm host Tandem
  rserver Tandem
    inservice
class-map match-all Prod
  2 match virtual-address 10.100.9.1 tcp any
class-map match-any SERVER-INITIATED
  2 match source-address 10.1.2.12 255.255.255.255
  4 match source-address 10.1.2.8 255.255.255.255
class-map type generic match-any xfr-ATMs
  2 match source-address 10.200.125.201 255.255.255.255
  3 match source-address 10.60.3.2 255.255.255.255
  4 match source-address 10.60.3.3 255.255.255.255
  5 match source-address 10.120.8.2 255.255.255.255
policy-map type loadbalance generic first-match LB-Prod
  class xfr-ATMs
    serverfarm RealTime
  class class-default
    serverfarm Tandem
policy-map multi-match Production
  class Prod
    loadbalance vip inservice
    loadbalance policy LB-Prod
    loadbalance vip icmp-reply active
policy-map multi-match src-natted-servers
  class SERVER-INITIATED
    nat dynamic 1 vlan 25
interface vlan 25
  description AO Public
  ip address 10.100.9.3 255.255.255.0
  no normalization
  no icmp-guard
  nat-pool 1 10.100.9.1 10.100.9.1 netmask 255.255.255.255 pat
  service-policy input Production
  no shutdown
interface vlan 236
  description AO RealTime
  ip address 10.1.2.3 255.255.255.0
  service-policy input src-natted-servers
  no shutdown
Thank you.
Brad
pthadani
How about creating VIPs based on the port e.g.:
class-map match-all Prod-RealTime
  2 match virtual-address 10.100.9.1 tcp 20073
  class Prod-RealTime
    loadbalance policy LB-Prod-RealTime
  class Prod
pthadani
  class Prod-RealTime
  class Prod
That did it! Thank you very much.
Brad
