ACE HTTP header response redirect does not work
mwannemacher
Visitor
hello team,
i am dealing for a while now with the issue, that we want to replace a windows server maschine doing in IIS only a redirect of http://autodiscover.domain.tld to https://autodiscover.exchange.tld/autodiscover. since it is needed for each client, there is "some" administrative overhead we want to prevent for  each new client.
so i configured the following in ACE (snipped)
action-list type modify http autodiscover-redirect
  header rewrite response location header-value "https://autodiscover.exchange.tld/autodiscover" replace "http://autodiscover.*.*"
action-list type modify http 80-to-443-rewrite
  ssl url rewrite location ".*"
 rserver redirect 01_redirect_80-to-443
  webhost-redirection https://%h%p 301
  inservice
rserver redirect 03_response_redirect_autodiscover
  webhost-redirection http://%h%p 301
serverfarm redirect 01_redirect_80-to-443
  rserver 01_redirect_80-to-443
    inservice
serverfarm redirect 03_response_redirect_autodiscover
  rserver 03_response_redirect_autodiscover
    inservice
class-map type http loadbalance match-all 02A_autodiscover.*.*
  2 match http header Host header-value "autodiscover.*.*"
  4 match http url /
policy-map type loadbalance first-match 21_Exchange-HTTPS-Policy
  class 02A_autodiscover.*.*
    action autodiscover-redirect
  class class-default
    sticky-serverfarm 21_Exchange-cookie-sticky_443
    action 80-to-443-rewrite
but it always is redirecting me directly within the same session to https://autodiscover.exchange.tld/autodiscover instead telling the client to make a new request for https://autodiscover.exchange.tld/autodiscover.
thank you for suggestions.
manuel
Kanwaljeet Singh
Hi Manuel,
Are you doing ssl termination on ACE? Also, send me the existing "interesting" configuration  and i will send you the configuration example.
Kanwal
Note: Please mark answers if they are helpful.
hello kanwal,
forst of all , thank you for your reply :).
in this case no.  i got it work this night (after hours of headache). my problem was the redirect of http requests to https on the same IP for direct exchange access.
so i altered the configuration as follows to another free IP and it works instantly:
  inservice
    inservice
action-list type modify http 141F_autodiscover-redirect
  header rewrite response location header-value "https://autodiscover.exchange.tld/autodiscover" replace "http://autodiscover[.]*[.]*"
class-map match-all 01_redirect_80-to-443-Class
  2 match virtual-address A.B.C.D tcp eq www
class-map match-all 141A_redirect_80-to-443-Autodiscover_Class
class-map type http loadbalance match-all 141C_autodiscover.*.*
  4 match http url /
policy-map type loadbalance first-match 01_redirect_80-to-443-Policy
  class class-default
    serverfarm 01_redirect_80-to-443
policy-map type loadbalance first-match 141B_redirect_80-to-443-Autodiscover_Policy
  class 141C_autodiscover.*.*
    action 141F_autodiscover-redirect
policy-map multi-match vlan_504_in
  class 141A_redirect_80-to-443-Autodiscover_Class
    loadbalance vip inservice
    loadbalance policy 141B_redirect_80-to-443-Autodiscover_Policy
    nat dynamic 110 vlan 21
but i recognized that the ACE is handling the redirect other than the ARR feature in windows 2012 since in windows for redirect we get a HTTP 200, in ACE the new URL is pushed back to the client and a SSL connection is made instantly.
in fact it works, but the HTTP => HTTPS redirect in windows seems faster than the ACE redirect. this is something i can not catch at the moment. may be we can improve the configuration?
thank you in advance.
manuel
