ACE HTTP loadbalancing problem
Darren Sasso
Level 3
Level 3
What i'm trying to achieve with the below config is
any request coming in with "programming" in the URL
will be mapped to one server and all else mapped to
a different. So what i see happening is that i can
get to the main page but not the page with "programming"
in the URL. I have to clear the connections to get
mapped to the serverfarm with that handles all requests
with "programming". I thought is was related to the
sticky serverfarm i had configured before so i reverted
to a ordinary serverfarm and it still doesn't work. Any
thoughts or suggestions????
rserver host TEST_01
ip address 10.10.204.200
inservice
rserver host TEST_02
ip address 10.10.204.201
inservice
serverfarm host TEST/PROG_SF
rserver TEST_02
inservice
serverfarm host TEST_SF
rserver TEST_01
inservice
class-map match-any TEST_VS
2 match virtual-address 10.10.215.27 tcp eq www
3 match virtual-address 10.10.215.27 tcp eq https
class-map type http loadbalance match-any TEST/PROG
3 match http url (/programming.*)
4 match http url /programming.*
policy-map type loadbalance first-match TEST_L7SLB
class TEST/PROG
serverfarm TEST/PROG_SF
class class-default
serverfarm TEST_SF
policy-map multi-match VIPS
class TEST_VS
loadbalance vip inservice
loadbalance policy TEST_L7SLB
loadbalance vip icmp-reply
interface vlan 215
service-policy input VIPS
Gilles Dufour
you need to activate persistent rebalance which is not on by default so that subsequent requests inside the same tcp connection can be remapped to a different server if matching a different rule.
parameter-map type http HTTP-PARAM
persistence-rebalance
class TEST_VS
appl-parameter http advanced-options HTTP-PARAM
Gilles.
Gilles Dufour
class TEST_VS
Gilles.
That worked!!! Thank you very much!!!
