ACE - HTTP not working when SSL is enabled
deephazz02
Hello All,
I have this case where HTTP stops working as soon as I configure the policy-map with a ssl-proxy server.
I've attached the config to the thread.
Did anybody ever come across the same issue?
Thibault.
access-list ALL line 10 extended permit ip any any
parameter-map type http ParseLen
persistence-rebalance
set header-maxparse-length 8000
rserver host PP105
ip address 10.118.228.105
conn-limit max 2000000 min 1500000
inservice
rserver host PP106
ip address 10.118.228.106
inservice
ssl-proxy service SSL_PreProd_Server
key PreProd.key
cert PreProd.cert
serverfarm host PreProdServers
predictor leastconns slowstart 18
probe TCP_80
rserver PP105 80
inservice
rserver PP106 80
inservice
sticky http-cookie preprod-cookie PreProd_Cookie_Sticky_Group
cookie insert
timeout 21
serverfarm PreProdServers
class-map match-any PreProd_Class
3 match virtual-address 10.10.10.12 tcp eq https
4 match virtual-address 10.10.10.12 tcp eq www
policy-map type loadbalance first-match PreProd_MAP
class class-default
sticky-serverfarm PreProd_Cookie_Sticky_Group
policy-map multi-match L4_VIP
class PreProd_Class
loadbalance vip inservice
loadbalance policy PreProd_MAP
loadbalance vip icmp-reply
loadbalance vip advertise active
appl-parameter http advanced-options ParseLen
ssl-proxy server SSL_PreProd_Server
interface vlan 123
description "client Side"
ip address 10.188.1.181 255.255.255.240
alias 10.188.1.179 255.255.255.240
peer ip address 10.118.1.180 255.255.255.240
access-group input ALL
access-group output ALL
service-policy input L4_VIP
no shutdown
interface vlan 456
descriptin "Server side"
ip address 10.188.208.124 255.255.255.224
alias 10.188.208.126 255.255.255.224
peer ip address 10.188.208.125 255.255.255.224
no shutdown
ip route 0.0.0.0 0.0.0.0 10.188.1.190
ciscocsoc
Level 4
Level 4
You need two class-maps because you are treating HTTP and HTTPS differently. In the HTTPS case you are terminating the SSL connection and retransmitting the packets to 80/tcp.
The example below is an extract from a context with similar requirements based on LDAP and LDAPS. We take in both LDAP and LDAPS and connect to the servers only with LDAP.
serverfarm host FARM-LDAP
rserver ldap1 389
inservice
rserver ldap2 389
inservice
rserver ldap3 389
inservice
rserver ldap4 389
inservice
class-map match-any L4VIPCLASS
2 match virtual-address 10.199.253.188 tcp eq 636
class-map match-any L4VIPCLASS-389
2 match virtual-address 10.199.253.188 tcp eq 389
policy-map type loadbalance first-match LB-POLICY
class class-default
serverfarm FARM-LDAP
policy-map multi-match L4POLICY
class L4VIPCLASS
loadbalance policy LB-POLICY
loadbalance vip icmp-reply active
nat dynamic 1 vlan 395
ssl-proxy server PSERVICE_SERVER
class L4VIPCLASS-389
Cathy
Thanks Cathy, I'll try and let you know.
Rgds,
Thibault.
So it worked. But that is frustrating because I have another context with HTTP and HTTPS under a single class and they both work without any problem. Sounds silly to say sometimes it works sometimes it doesn't....
Thanks for you answer.
Rgds,
Thibault.
