ACE in a routed mode
helsayed78
Guys,
Should the ACE be the gateway for the load balanced servers in a routed mode scenario ? If yes then why ?
litrenta
Level 3
Level 3
yes ACE interface on server vlan should be gateway. routed mode implies layer 2 adjacency of servers and ace. If ace is not the gateway and you are not doing source nat on ace then servers would respond around the ace to client via it's gateway. unless specifically configured for direct server return client would be seing response from server address rather than vip resulting in failure.
Thank you for your reply, but can you elaborate more on this?
