ACE is not booting up
ranjith.kanisan
Hi Team,
In the ACE console, we are seeing
uncompressing linux... ok booting the kernel
But box is not booting up. Kindly suggest is this a hardware issue?
Ranjith
sivaksiv
Hi Ranjith,
Do you have a screen and/or keyboard connected to a device, by chance? If yes, you will need to disconnect them, reboot and see if it boots normally.
Also can you attach all the console output during the boot process?
Siva
sivaksiv
Hi Ranjith,
Siva
Hi Siva,
After disconnected the pheripheral, and reboot box is up and running.
Thanks for your support.
Ranjith
