Ace load balance port 8091
frede_frede
I need to balance port https in port 8091, I already make this configuration in port 443 and works, but with port 8091 the sessions are broken and the users have to constantly make login
probe tcp KPalive_server_8091
  port 8091
  interval 10
  faildetect 2
  passdetect interval 10
  passdetect count 2
  open 1
rserver host server01
  ip address 192.168.32.128
  inservice
rserver host server02
  ip address 192.168.32.129
serverfarm host SRVfarm_server
  probe KPalive_server_8091
  rserver server01
    inservice
  rserver server02
    inservice
sticky layer4-payload server_HTTPS
  serverfarm SRVfarm_server
  response sticky
  layer4-payload offset 43 length 64 begin-pattern "(\x20|\x00\xST)"
class-map match-all CLA4_HTTPS
  2 match virtual-address 192.168.30.60 tcp eq 8091
policy-map type loadbalance generic first-match POL7_HTTPS
  class class-default
    sticky-serverfarm server_HTTPS
policy-map multi-match POL4_HTTPS
  class CLA4_HTTPS
    loadbalance vip inservice
    loadbalance policy POL7_HTTPS
    loadbalance vip icmp-reply active
thanks
Fred
A mensagem foi editada por: Frederico Fred
Kanwaljeet Singh
Hi Fred,
If i have understood you correctly you want that traffic coming to VIP at 443 should be sent back to the server on port 8091, then you should make a slight change in config.
rserver server01 8091
inservice
rserver server02 8091
inservice
You should define the port at which ACE should send the traffic to server after taking a LB decision.
Let me know if that helps.
Kanwal
Kanwaljeet Singh
Hi Fred,
inservice
inservice
Kanwal
