Ace Load Balance servers in different port than VIP address
tgandoy
While this is quite simple in a CSS configuration,  I could not find yet how to do this with an ACE:
- VIP address listen port TCP http
- Load balancing have  to be done between rservers 1 and 2 listen on port 8030.
So what I mean is,  users will connect to http://"vipaddress" but connections will go to rserver1 and rserver2 on port 8030.
Thanks.
Toni.
Borys Berlog
Hi Toni
In ACE it's quite simple too (but I agree may be confusing after CSS)
Basically when you create serverfarm , you put it like this :
serverfarm host X
rserver X1 8030
inservice
So, port which is going to be used between ACE and real server is specified in serverfarm.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/slb/guide/rsfarms.html#wp1000363
Jorge Bejarano
Level 4
Level 4
Hey Toni,
Here you have a sample about it:
interface vlan 112
  ip address 10.198.16.71 255.255.255.192
  peer ip address 10.198.16.72 255.255.255.192
  mac-sticky enable
  access-group input ACCESS-ANS
  nat-pool 126 10.198.16.126 10.198.16.126 netmask 255.255.255.192 pat
  service-policy input ANS-MGT
  service-policy input CLIENTS
  no shutdown
class-map match-any VIP-126
  2 match virtual-address 10.198.16.126 tcp eq www
policy-map multi-match CLIENTS
  class VIP-126
    loadbalance vip inservice
    loadbalance policy POLICY
    loadbalance vip icmp-reply
    nat dynamic 126 vlan 112
    appl-parameter http advanced-options CASE_PARAM
policy-map type loadbalance first-match POLICY
  class class-default
    serverfarm SERVERFARM
serverfarm host SERVERFARM
  probe PROBE
  rserver server1 8030
    inservice
  rserver server2 8030
    inservice
rserver host server1
  ip address 10.198.16.93
  inservice
rserver host server2
  ip address 10.198.16.92
  inservice
Jorge
Thanks everybody for the quick answer.
Actually was easy too.
Sounds great!!!
Jorge
