ACE Load-balancers and TCP inactivity timeout
mnettlesNTTA
We know the default TCP Idle timeouts are: inactivity timeout (seconds)       : TCP: 3600, UDP: 10, ICMP: 2, HTTP/SSL: 300
My question is there any way to change JUST the http/S setting,  I.E. make the timeouts:
inactivity timeout (seconds)       : TCP: 3600, UDP: 10, ICMP: 2, HTTP/SSL: 1800
Right now making a class map to match http and https, but woudl be real nice if I could set the global system wide parameters to:
Rather then setting the system wide parameters to:
inactivity timeout (seconds)       :1800
mnettlesNTTA
Unfortunately I only have a live system,  so can't easily test, but I have worked out the below is somebody could agree that it would do what I think (change idle timeout for http and https for all inbound traffic on the respective interfaces)
parameter-map type connection PAMAP_HTTP_SSL_1800 set timeout inactivity 1800
class-map match-any CMAP_HTTP_SSL
  match port tcp eq https
policy-map multi-match PMAP_HTTP_SSL_1800
  description Custom HTTP/S Idle Timeout Value
  class CMAP_HTTP_SSL
    connection advanced-options PAMAP_HTTP_SSL_1800
interface vlan 123
service-policy input PMAP_HTTP_SSL_1800
interface vlan 629
interface vlan 630
interface vlan 641
interface vlan 642
(Edit: corrected class-map syntax)
As a bonus can somebody confirm how to change it to apply not to all http/https traffic but specific IP/networks
I think it would be:
ip access-list extended TCP_IDLE_TIMEOUT
 permit tcp any host x.x.x.x eq http
 permit tcp any host  x.x.x.x eq https
and then change class-map to:
 description Destination IP for PMAP_HTTP_SSL_1800
 match access-list TCP_IDLE_TIMEOUT
My concern would be (more used to ACLs then policy/class maps)....  is this going to deny traffic that does not match the above?
