ACE load balancing and testing using soapUI
anghesomt
Community Member
Hey, I am trying to crowd source a solution for this problem.
A client is testing using soapUI to an application that is being load balanced via ACE. There are two webservers behind the VIP servicing the client request. When client tests, requests are timing out per the soapUI log. A packet capture was taken and it clearly shows that ACE is not forwarding the HTTP data back to the client. When client tests by bypassing the ACE load balancer, it works fine. But, there are other clients from other applications that are making successful connection to the load balanced application via the VIP.
Question, is there any thing unique with making HTTP/XML based requests using soapUI? LB configuration is shown below:
class-map match-all EAI_PWS_9083
  2 match virtual-address 10.5.68.29 tcp eq 9083
serverfarm host EAI_PWS_9083
  description WebSphere Porduction
  failaction purge
  probe tcp9083
  rserver ESSWSPAPP01 9083
    inservice
  rserver ESSWSPAPP02 9083
    inservice
policy-map type loadbalance first-match L7_POLICY_EAI_PWS_9083
  class class-default
    serverfarm EAI_PWS_9083
policy-map multi-match L4SLBPOLICY
class EAI_PWS_9083
    loadbalance vip inservice
    loadbalance policy L7_POLICY_EAI_PWS_9083
    loadbalance vip icmp-reply active
    appl-parameter http advanced-options CASE_PARAM
parameter-map type http CASE_PARAM
  case-insensitive
Kanwaljeet Singh
Your configuration looks fine. I am not familiar with soapUI but if it is like a normal TCP connection followed by HTTP requests, i don't see why this shouldn't work.
Do you know if there is a difference while using soapUI and normal request using browser?
Kanwal
