ACE logging - rserver and probes
sthon-dbsys
on CSS I get an info if a server fails the keepalive and get in state "down, up or suspended". This is logged in the traplog file on the CSS.
Is there any possibility on an ACE to have logs for rserver state changes like "PROBE-FAILED, OPERATIONAL and OUT-OF-SERVICE"
thx in advance
10 Replies 10
Gilles Dufour
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/system/message/guide/messags.html#wp1125682
251006
Error Message %ACE-3-251006: Health probe failed for server A.B.C.D on port P,
internal error: error message
If you enable logging at level error or higher you should see these probe failed messages.
Gilles.
Hi Gilles,
1. looks fine, but I miss the rserver Name in the log. it only appears the ip address of the server.
So it looks like that the "ip address log" is implemented :-(
b-sllb2001-09/db_bku-nK2# show rserver sthon
rserver : sthon, type: HOST
state : PROBE-FAILED
----------connections-----------
real weight state current total
serverfarm: test.db.de
172.24.100.98:0 8 PROBE-FAILED 0 0
b-sllb2001-09/db_bku-nK2# show logging | i ACE-3
Jun 25 2008 09:20:14 : %ACE-3-251011: ICMP health probe failed for server 172.24.100.98, server reply timeout
Jun 25 2008 09:20:23 : %ACE-3-251011: ICMP health probe failed for server 172.24.100.98, server reply timeout
Jun 25 2008 09:20:54 : %ACE-3-251011: ICMP health probe failed for server 172.24.100.98, server reply timeout
Jun 25 2008 09:21:54 : %ACE-3-251011: ICMP health probe failed for server 172.24.100.98, server reply timeout
2. I can find nothing in the log when the probe gets "operational" or "out-of-service state".
Is thos correct ?
state : OPERATIONAL
172.24.100.98:0 8 OPERATIONAL 0 0
Actually, looking into the code, there are messages for rserver going up and down.
#define REAL_SERVER 442 /* REAL_SERVER group id */
#define REAL_SERVER_STATE_UP_ID 4442001
#define REAL_SERVER_STATE_DOWN_ID 4442002
#define REAL_SERVER_STATE_CHANGE_ID 4442003
#define RSERVER_STATE_UP_ID 4442004
#define RSERVER_STATE_DOWN_ID 4442005
#define RSERVER_STATE_CHANGE_ID 4442006
They are displayed at level 4
Gilles.
Hi Gilles,
i have configured the following log levels:
b-sllb2001-09/db_bku-nK2# show run | i loggin
Generating configuration....
logging enable
logging fastpath
logging timestamp
logging trap 7
logging buffered 7
logging monitor 7
in my opinion "logging buffered 7" includes the level 4 infos/errors,
but I have definetly NO infos in the log.
please can you double check this
thx
switch/Admin(config)# rserver 10.10.10.10
switch/Admin(config-rserver-host)# no ins
switch/Admin(config-rserver-host)# do sho logg | i rser
%ACE-5-111008: User 'admin' executed the 'rserver 10.10.10.10' command.
switch/Admin(config-rserver-host)# do sho logg | i out
%ACE-4-442006: Real Server 10.10.10.10 changed state to outOfService
This matches the info I gave you previously.
Gilles.
this looks fine, but doesn't work in my config:
1. what ace SW do you use ?
we have system: Version 3.0(0)A1(6.2) [build 3.0(0)A1(6.2) adbuild_23:41:40-2007/10/18_/auto/adbure-rel2/ws/REL_3_0_0_A1_6_2]
2. how is your logging configured ?
we have:
logging enable
logging fastpath
logging timestamp
logging trap 7
logging buffered 7
logging monitor 7
This was fixed in A2.1
Gilles.
Hi Gilles,
I have tested this issue with SW
sllb# show ver
Software
loader: Version 12.2[120]
system: Version A2(1.0a) [build 3.0(0)A2(1.0a) adbuild_04:14:49-2008/04/18_/auto/adbu-rel3/rel_a2_1_throttle/REL_3_0_0_A2_1_0A]
system image file: [LCP] disk0:c6ace-t1k9-mz.A2_1_0a.bin
installed license: ACE-08G-LIC ACE-SEC-LIC-K9
Jun 26 2008 14:05:15 : %ACE-4-442006: Real Server sthon changed state to inService
Jun 26 2008 14:08:01 : %ACE-4-442003: Real Server sthon in serverfarm athene-abn.bahn-net.db.de changed state to inService
Jun 26 2008 14:52:49 : %ACE-3-251010 Health probe failed for server 10.183.186.120 on port 443, connection refused by server
Jun 26 2008 14:53:49 : %ACE-3-251010 Health probe failed for server 10.183.186.120 on port 443, connection refused by server
Jun 26 2008 14:54:49 : %ACE-3-251010 Health probe failed for server 10.183.186.120 on port 443, connection refused by server
but I cannot find any log with state changes to operational.
also bad, that the probe-failed is logges with the IP Address and the rserver infos with the rserver name :-(
Here is what I get if I play with probes.
You get the up and down.
You get the real name and the serverfarm name.
Can't be better than that :-)
Jun 26 2008 13:10:08 : %ACE-4-442002: Health probe down detected linux1 (interfa
ce bvi30) in serverfarm linux1-80 changed state to DOWN
un 26 2008 13:10:17 : %ACE-3-251008: Health probe failed for server 192.168.30.
27 on port 80, connectivity error: server open timeout (no SYN ACK)
Jun 26 2008 13:11:25 : %ACE-4-442001: Health probe myhttp detected linux1-24 (in
terface vlan30) in serverfarm linux1-80 changed state to UP
Jun 26 2008 13:11:37 : %ACE-4-442001: Health probe myhttp detected linux1 (inter
Gilles.
I can confirm this. My Q&A ACE runs A2.1 and shows this messages in the log as well.
The Prod. ACE runs A2.0 and doesn't show this message.
Roble
