ACE Module and Limiting Connections
svacca
We currently use the ACE module to Load-balancing IPSEC connection into SPA's.  Since the SPA's only support 60 new connections per second.  I was looking for a way to limit the amount of connecitons from the ACE to the SPA's.
Sean Merrow
Level 4
Level 4
Have a look at the Configuring Real Server Rate Limiting section of the ACE documentation.  I think this will meet your needs.
Hope this helps,
Sean
