ACE module configuring NTP
andre.hansel
Visitor
I tried to configure an NTP Server and / or peer as described in the ace_adgd but the command NTP is not even there in the configuration mode of the Admin context. Is there a known issue with software version A2(1.0) or is there a configuration dependancy relating to ntp ? Many thanks in advance for your help and kind regards,
Andre
dario.didio
Level 9
Level 9
There is no possibility to configure NTP on an ACE module.
The ACE will take the time settings from the Supervisor.
Hope this helps.
Dario
dario.didio
Level 9
Level 9
Hope this helps.
Dario
Thanks Dario.
I just configured the timezones similar to SUP settings by hand and will check if it works.
Cheers, Andre
