ACE Module & FWSM
pemalcoun
Frequent Visitor
Frequent Visitor
Dear Gents,
Attached is the current setup & configuration for both ACE & FWSM.
we can ping the VIP from the user side, but we are not able to open the web application using the VIP.
Appreciate your kind support to solve the issue when trying to open the application using the VIP.
Best Regards,
pemalcoun
Frequent Visitor
Frequent Visitor
Dear All,
I changed the setup to one armed mode and modifed the configuration and it is working fine.
BR
Pierre this is babu.
     Can you please forward ACE ONE ARM MODE current configuration which is working fine. Check my configuration and please replay if any modification require.
boot system image:c4710ace-mz.A4_2_0.bin
interface gigabitEthernet 1/1
switchport access vlan 255
no shutdown
interface gigabitEthernet 1/2
switchport access vlan 110
no shutdown
interface gigabitEthernet 1/3
shutdown
interface gigabitEthernet 1/4
shutdown
access-list ALL line 8 extended permit ip any any
access-list ALL line 16 extended permit icmp any any
probe http HTTP
port 80
interval 20
passdetect interval 40
receive 3
expect status 0 499
connection term forced
open 1
probe icmp PING
description Probe PING
interval 2
faildetect 2
passdetect interval 2
passdetect count 2
receive 1
probe snmp SNMP-PROBE
description SNMP-PROBE
interval 15
passdetect interval 10
version 2c
community MODA-MSD-RW
oid .1.3.6.1.2.1.4.3.0
   type absolute max 1000000000
weight 6000
rserver host SERVER1
description msd-hq-sp01
ip address 10.0.160.14
conn-limit max 2000000 min 1500000
rate-limit connection 100000
rate-limit bandwidth 10000000
inservice
rserver host SERVER2
description msd-hq-sp02
ip address 10.0.160.15
fail-on-all
weight 20
inservice
rserver host SERVER3
fail-on-all
weight 30
inservice
rserver host SERVER4
fail-on-all
weight 40
inservice
serverfarm host MoDA-MSD-SFARM
description MoDA-MSD-SERVERS
probe PING
rserver SERVER1 80
   rate-limit bandwidth 5000000
   inservice
rserver SERVER2 80
   inservice
sticky ip-netmask 255.255.255.255 address source STKY_WEB1
timeout 60
replicate sticky
serverfarm MoDA-MSD-SFARM
class-map match-all frontend
2 match virtual-address 10.0.160.17 tcp eq www
class-map type management match-any remote_access
2 match protocol xml-https any
3 match protocol icmp any
4 match protocol telnet any
5 match protocol ssh any
6 match protocol http any
7 match protocol https any
8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
class remote_access
   permit
policy-map type loadbalance first-match frontend
class class-default
policy-map multi-match CLIENT-VIPS
class frontend
   loadbalance vip inservice
   loadbalance policy frontend
   loadbalance vip icmp-reply
   nat dynamic 1 vlan 110
class class-default
interface vlan 110
ip address 10.110.10.101 255.255.255.0
access-group input ALL
nat-pool 1 10.110.10.200 10.110.10.200 netmask 255.255.255.0 pat
service-policy input CLIENT-VIPS
service-policy input remote_mgmt_allow_policy
no shutdown
interface vlan 255
ip address 10.0.255.245 255.255.255.0
no shutdown
ft interface vlan 115
ip address 10.1.1.1 255.255.255.0
peer ip address 10.1.1.2 255.255.255.0
no shutdown
ft peer 1
heartbeat interval 300
heartbeat count 20
ft-interface vlan 115
query-interface vlan 110
ft group 1
peer 1
priority 120
associate-context Admin
inservice
ip route 0.0.0.0 0.0.0.0 10.110.10.254
snmp-server community MODA-MSD-RO group Network-Monitor
snmp-server host 10.0.160.144 traps version 2c MODA-MSD-RW
snmp-server enable traps snmp coldstart
snmp-server enable traps virtual-context
snmp-server enable traps license
snmp-server enable traps slb vserver
snmp-server enable traps slb real
snmp-server enable traps syslog
snmp-server enable traps snmp authentication
snmp-server enable traps snmp linkup
snmp-server enable traps snmp linkdown
username admin password 5 $1$D1e1pS1d$KBuTV0Oe195u3b3dW9RQF/ role Admin domain
default-domain
username www password 5 $1$JfHnQdU/$0FLEMgeJIuAzIKGc3Xv.p1 role Admin domain de
fault-domain
ssh key rsa 1024 force
Thank you,
Babu.S
