ACE module in ASN set up not passing URL
Phyziks42
Hello all,
I have an interesting issue. I have an ACE30 set up in ASN mode (see http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA5_1_0/configuration/slb/guide/slbgd.html)
I do see the connection to the server establish, but the server admin informs me that they are performing URL filtering and that my packets do not contain a URL! I am not sure what exactly I should do about this.
Config on ACE context:
access-list INBOUND line 10 extended permit ip any any
probe https TMG-Exchange
  ssl version all
rserver host real1
  ip address 10.50.102.77
  inservice
rserver host real2
  ip address 10.50.102.78
  inservice
serverfarm host FARM_VIP_10.50.103.239
  transparent
  rserver real1
    inservice
  rserver real2
    inservice
class-map match-all VIP_CLASS
  2 match virtual-address 10.50.103.239 any
class-map type management match-any mgmt-cm
  2 match protocol icmp any
  3 match protocol ssh source-address 10.48.0.0 255.240.0.0
policy-map type management first-match mgmt-pm
  class mgmt-cm
    permit
policy-map type loadbalance first-match lbpol
  class class-default
    serverfarm FARM_VIP_10.50.103.239
policy-map multi-match LBPOL
  class VIP_CLASS
    loadbalance vip inservice
    loadbalance policy lbpol
    loadbalance vip icmp-reply active
    loadbalance vip advertise active
interface vlan 102
  description ONE ARM VLAN
  ip address 10.50.102.96 255.255.255.0
  no normalization
  access-group input INBOUND
  service-policy input LBPOL
  service-policy input mgmt-pm
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.50.102.251
Any ideas?
Jorge Bejarano
Level 4
Level 4
Hello Mikael,
Could you explain yourself better? Do you mean you need to match a specific URL or what exactly?
Jorge
I do not need to match a specific URL. The application on the server does however. The server admin reports that connection is being refused as there is no URL included to match.
When setting this up as a one-arm config with source NAT everything works fine. Unfortunately, it is a requirement of the application that the client IP remain intact.
