ACE module monitor server sessions and probs
aymn_louis
i've cisco 6500 with ace module load balancing my application environment ..
my question is :
the application people requesting always to know the number of connections on each server which could be done from the "show serverfarm" command
also the need the show probe command ..
how can i gave them these data without giving them access on the ACE module CLI ?
is there a method to export such output periodically ? or a certain application to got it out ?
Daniel Arrondo Ostiz
Hi Aymn,
For what you are trying to achieve, the easiest would probably be to poll the data through SNMP. I would recommend you to have a look at the CISCO-SLB-EXT-MIB and CISCO-SLB-HEALTH-MON-MIB to see what are the exact OIDs you want to poll.
Daniel
