ACE module RBAC
Sergey Fuklev
Frequent Visitor
Frequent Visitor
Good day.
I have a question about RBAC on Cisco ACE.
Is it a possible create user role, whitch allowed monitor serverfarm state ("show serverfarm xxx" {detail} command), but restrict "show running/startup config" commands?
Configuration like following did not work (show commands not available):
role tst
    rule 1 permit monitor feature serverfarm
    rule 2 deny monitor
However Virtual Configuration Guide said ''The rule number determines the order in which the ACE applies the rules, with a higher-numbered rule applied after a lower-numbered rule''.
So it is possible to accomplished?
chrhiggi
Level 8
Level 8
Hello Anatoliy-
  Show run is permitted for all roles,/features, there is no way to disable it.
  Chris Higgins
