ACE Module Reverse Proxy with URL rewrite
virajmendis
Visitor
Hi All,
Try to configure ACE as reverse proxy for WebLogic server farm. But have a issue on Rewriting URL.
http://172.16.36.100/test1/ -> http://192.168.1.20:8080/test1/ This is Possible.
But, http://172.16.36.100/test1/ -> http://192.168.1.20:8080/test2/
T tried this with redirection server farm. redirection works but the cannot see the pages wich coming after the /test1/xxxxxxxxx.xxxx and redirection can experiance the client since URL change on browser.
Is there a any other logic?
Have anyone tried this before?
Vira
litrenta
Level 8
Level 8
You won't be able to do this on the ace. When using a redirect server you can preserve the path with the %p variable but in this case you want to rewrite part of the path
so
webhost redirection http://192.168.1.20:8080/test2%p
winds up being
http://192.168.1.20:8080/test2/test1/...
Yes, I tried with %p variable. It's not work.
But the datasheet said HTTP header manipulation is possible with ACE. This feature support only with SSL?
Thanks…..
you can manipulate the header...not the url.
Everything after the url can be modified, removed, added...
So if your server sends a redirect, you can intercept it and change the Location: header.
But again, you can't change the url.
Gilles.
