ACE module rservers multiple routed hops away
thedinuka
Hi all, deploying a ACE module in a cat6k. Just want to figure out, can I add to a serverfarm, rservers which are multiple routed hops away from the ACE or the cat6k in which it is deployed. please look at the attached diagrams. I have my servers at two subnets, and I want to add all 5 servers to the same server farm and load balance between them
Is this possible, if any what are the caveats ?
Thanks all
ciscocsoc
Level 4
Level 4
You can do this, but ypu have to use client-NAT to force the return traffic to pass back through the ACE. You also then need static routes in the ACE context to point at each server.
The following extract from a configuration shows the basic principle:
rserver host master
ip address 10.199.95.2
inservice
rserver host slave
ip address 10.199.38.68
inservice
serverfarm host FARM-web2-Master
description Serverfarm Master
probe PROBE-web2
rserver master
inservice
serverfarm host FARM-web2-Slave
description Serverfarm Slave
probe PROBE-web2
rserver slave
inservice
class-map match-any L4VIPCLASS
2 match virtual-address 10.199.80.12 tcp eq www
3 match virtual-address 10.199.80.12 tcp eq https
policy-map type management first-match REMOTE-MGMT-ALLOW-POLICY
class REMOTE-ACCESS
permit
policy-map type loadbalance first-match LB-POLICY
class class-default
serverfarm FARM-web2-Master backup FARM-web2-Slave
policy-map multi-match L4POLICY
class L4VIPCLASS
loadbalance vip inservice
loadbalance policy LB-POLICY
loadbalance vip icmp-reply active
loadbalance vip advertise
nat dynamic 1 vlan 384
service-policy input L4POLICY
interface vlan 383
description ACE-web2-Clientside
ip address 10.199.80.13 255.255.255.248
alias 10.199.80.12 255.255.255.248
peer ip address 10.199.80.14 255.255.255.248
access-group input ACL-IN
access-group output PERMIT-ALL
no shutdown
interface vlan 384
description ACE-web2-Serverside
ip address 10.199.80.18 255.255.255.240
alias 10.199.80.17 255.255.255.240
peer ip address 10.199.80.19 255.255.255.240
access-group input PERMIT-ALL
nat-pool 1 10.199.80.20 10.199.80.20 netmask 255.255.255.240 pat
no shutdown
ip route 0.0.0.0 0.0.0.0 10.199.80.9
ip route 10.199.95.2 255.255.255.255 10.199.80.21
ip route 10.199.38.68 255.255.255.255 10.199.80.21
Cathy
