ACE Module TCP Inactivity timeout
stevek1
Level 3
Level 3
Hi Folks,
Can anyone assist with a fix for the following issue on traffic through the ACE module?
TCP sessions are being reset after 60 minutes of inactivity (default behaviour I understand). I need to extend this to 7500 seconds.
Our ACE sits between the internal corporate network and the corporate (CheckPoint) Firewall. The FW administrators are seeing TCP resets coming from the internal network (ie...the ACE) after exactly 60 minutes of inactivity. 2 applications need these connections to remain open for at least 2 hrs.
I thought perhaps I should apply a parameter-map to the server side interface as well as the client side (where it is already applied). I currently have a server side policy-map of type "management". I expect this wouldn't have effect on application traffic in this case so what if I configure a new policy-map of type "multi-match" on server-side? For example if I configured the following:
existing parameter-map is....
parameter-map type connection External_Connections
set timeout inactivity 7500
create....
policy-map multi-match ServerSide_FW_DR_L4_LB_VIP_POLICY
class class-default
connection advanced-options External_Connections
apply....
interface vlan 3390
service-policy input ServerSide_FW_DR_L4_LB_VIP_POLICY
1 - Would this do the job?
2 - Would it only affect the TCP inactivity timeout and otherwise leave everything else alone (not break anything)?
Attached are show techs for the switch and the module.
Grateful for any assistance with this.
Kind Regards,
SteveK
6 Replies 6
Default inactivity timeouts used by ACE are
icmp 2sec
tcp 3600sec
udp 120sec
With your config you will change inactivity for every protocol to 7500sec.If you want to change TCP timeout to 7500sec and keep the
other inactivity timeouts as they are now use following
parameter-map type connection GLOBAL-TCP
set timeout inactivity 600
parameter-map type connection GLOBAL-UDP
set timeout inactivity 120
parameter-map type connection GLOBAL-ICMP
set timeout inactivity 2
class-map match-all ALL-TCP
match port tcp any
class-map match-all ALL-UDP
match port tcp any
class-map match-all ALL-ICMP
match port tcp any
policy-map multi-match TIMEOUTS
class ALL-TCP
connection advanced GLOBAL-TCP
class ALL-UDP
connection advanced GLOBAL-UDP
class ALL-TCP
connection advanced GLOBAL-ICMP
and apply service-policy TIMEOUTS globally
Syed Iftekhar Ahmed
Thanks for your response Syed,
Just to clarify...
1 - for GLOBAL-TCP you typed 600. Should that read 7500?
2 - When you say "apply service-policy TIMEOUTS globally", are you suggesting I apply these as input service-policies to each vlan interface? I already have multi-match policies applied to the client side interface so can I apply another one? Or is there a way to configure globally?
Cheers, SteveK.
The service-policy can be applied globally in the config instead of having to configure it in every interface.
That's what was suggested to you.
Gilles.
Many thanks Syed and Gilles,
I see how to do that now, I'm new to ACE modules and wasn't used to the concept of global application of a service policy.
Your valuable contributions are much appreciated. Keep up the good work.
SteveK.
Hi, Is this config apply to all traffic ? I want to say balanced and non-balanced or just for that traffic that hit one VIP ?
Thanks in advantage
Tiago
According to above example it will apply to everything.
Kanwal
