ACE Module throughput
patrik.spiess
Level 3
Level 3
In the Datashhet of the ACE-Module (ACE20-MOD-K9) there is the following promise:
Throughput
16 Gbps*, 8 Gbps*, and 4 Gbps
We have a base license, so I assume we have a throughput of 4Gbps (gigabits per second).
Are these 4Gbps bidirectional or unidirectional?
Is it 2Gbps in one direction and 2Gbps in the other direction?
Imagine we have just 1 host (A) before the ACE module and just 1 host (B) behind the ACE module. Can I transfer data from A to B (unidirectional) with 4Gbps? Assume the hosts are connected with 10Gbps to the network and use multiple flows!
How can I measure the effective used bandwith on the ACE module?
What hapens, if host A tries to send data faster than 4Gbps? Does it deny single packets? Base on what? Does it deny additional sessions?
How do I know that the ACE runs at it's bandwith limitation?
Any Ideas?
Patrik
Daniel Arrondo Ostiz
Hi Patrik,
See my answers inline:
It measures the total throughput going through the box. It includes both directions. Also take into account that, for any traffic through the ACE, the packets are seen twice (client to ACE and ACE to server), so the effective throughput is half of the licensed one.
You could get up to 2Gbps unidirectional. This traffic will go through the ACE twice, adding to the 4Gbps license
With the "show resource usage" command
It will drop packets that go over the bandwidth without taking into account to which connection they belong
Again, "show resource usage"
Daniel
Hi Daniel
I don't agree with that statement. As far as I see, our link to the backup server has a maximum throughput of ~ 2.2 Gbps, which is above your stated maximum throughput.
Now, in the other thread we discussed the resource allocation. I did the following allocation:
ADMIN: limit-resource all minimum 5.00 maximum equal-to-min
NOZONE: limit-resource all minimum 10.00 maximum equal-to-min
ZONE1: limit-resource all minimum 10.00 maximum unlimited
ZONE2: limit-resource all minimum 10.00 maximum unlimited
ZONE3: limit-resource all minimum 10.00 maximum unlimited
ZONE4: limit-resource all minimum 10.00 maximum unlimited
So, this means, that my ZONE1 (where I have the performance issue) can only have up to 55% of all resources, because the rest is reserved as minimum for the other contexts.
Then just calculate: 2,2Gbps / 55% * 100% equals to exactly 4Gbps. This leads to the conclusion that the maximum throughput is 4Gbps, if I reduce all the contexts minimum to 0%.
Maybe it helps to know that we operate the module in layer 2 mode?
regards
Patrik
