ACE Performance Issues
gsarivu07
Community Member
We have ACE module intergrated in cisco 6509 switch. We have performance issue for specific url while accessing through ACE, but it works normal when works with direct url.
The users are getting error at middle of works , " applications are unable to get  data ". We have configured http-cookie sticky like below,
The issues are not occured at any specific time.
sticky http-cookie ACE-Insert web-sticky
  cookie insert
  replicate sticky
  serverfarm webfarm
Note: We are using two rserver in serverfarm and enabled port-80 services.
Could you please suggest how can we locate/narrow down the root cause of the issues.
acebee
jbartoldus
Community Member
Can you post the rest of the config?
The remaining configurations are basic and regular layer 3-4 class map and policy map only. Sorry I don't have configuration right now.,
br,
acebee
Cesar Roque
Level 8
Level 8
Hi Acebee,
What is exactly the problem? slowness?  how long it takes to load the website?
Did you try with sticky based on source-IP?
Is an ACE module or ACE appliance?
Please send me the rest of the configuration or a showtech if possible
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hi Cesar,
  • Its not a slowness issues, the page is loaded as expected,but sometime ( middle of the work)  it is  not working properly and throws the application error message saying that the "application cannot get data from the server."
       No general error message except for the application specific is shown
  • We tried source IP sticky as well , but no luck.
  • I don't have full config now, but I observed that we have defined layer3 & 4 class map and used same VIP for three different port service, but in real we are using port 80 (www) only.
Please find the sample config below
sticky http-cookie ace.acebee.com  ace.acebee.com
  cookie insert
  replicate sticky
  serverfarm ace.acebee.com
class-map match-any ace.acebee.com
  description classmap for ace.acebee.com
  2 match virtual-address 10.9.6.1 tcp eq www
  4 match virtual-address 10.9.6.1 tcp eq https
  6 match virtual-address 10.9.6.1 tcp eq 8088
Do you think that the unused  VIP with service https and 8088 is disturbing the perofrmance of application ?
acebee
