ACE port redirection problem
majaj
I am using standard http port 80 in front end (between the end user and ACE module ) and I am using port 9080 for backend (between the ACE and servers).
I don't want the port number 9080 to show up in the url
http://www.Trading.com:9080/ANTOnline
how can i hide the port 9080 from the end user
Gilles Dufour
If the vip is configured with port 80 and your real with port 9080, ACE should be doing the nating transparently and the client browser going to port 80 should not display port 9080.
Gilles.
actually , i am getting port 9080 in the url
can you check attached configuration please
You are getting the port 9080 because your server is sending a redirect to the browser.
The redirect will contain the port 9080.
You need to block the redirect and create your own from ACE.
So, you need to identify which request triggers the redirect, intercept this request with a class-map and generate your own redirect from ace.
Get a sniffer trace to see the redirect.
Gilles.
celiocarreto
Level 4
Level 4
Try this config:
rserver host Server001
ip address 10.1.1.1
inservice
rserver host Server002
ip address 10.1.1.2
inservice
serverfarm host SF001
probe CHECK.HTML
rserver Server001 9080
inservice
rserver Server002 9080
inservice
class-map match-all R001
2 match virtual-address 1.1.1.1 tcp eq www
policy-map type loadbalance first-match P001
class class-default
serverfarm SV001
policy-map multi-match L4-LB
class R001
loadbalance vip inservice
loadbalance policy P001
loadbalance vip icmp-reply
It should solve your problems
