ACE redirection issue
we have our main website https://abc.com and it provides links to users for various applications.
If i go to https://abc.com and click the link xyz on it, i get back to main page again and current  connections drops to 0. here my browser should be redirected to https://abc.com/xyz which is not happening. Traffic is getting tunnnled to https://abc.com as seen in logs in http catcher.
But if i type in https://abc.com/xyz in browser, i go to correct page.
below  is my configuration. please let me know if any other configuration is  needed, Below config is with 2 links but actual production has many  links.
I have similar issue for another application where links on  main page can not be accessed. that application works on http  instead  of https.
rserver redirect xyz
  inservice
  webhost-redirection "https://abc.com/xyz"
rserver redirect uvw
  inservice
  webhost-redirection "https://abc.com/uvw"
rserver host abc
ip address 1.1.1.1
inservice
serverfarm redirect xyz
rserver xyz
inservice
parameter-map type http case_param
  case-insensitive
  no persistence-rebalance (i also tried enabling it)
  set header-maxparse-length 65535
  set content-maxparse-length 65535
  length-exceed continue
parameter-map type ssl abc
  cipher RSA_WITH_3DES_EDE_CBC_SHA
ssl-proxy service abc
  key abc
  cert abc
  ssl advanced-options abc
serverfarm redirect uvw
rserver uvw
inservice
serverfarm host abc
rserver abc
inservice
class-map type http loadbalance match-any map1
   match http url /xyz.*
   match http url /uvw.*
policy-map type loadbalance first-match ssl-abc
class map1
    serverfarm xyz
class map2
    serverfarm uvw
class class-default
    serverfarm abc
class ssl-intranet
    loadbalance vip inservice
    loadbalance policy ssl-abc
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 368
    appl-parameter http advanced-options case_param
    ssl-proxy server abc
the IP address mentioned for abc.com (1.1.1.1) is on cisco CSS (VIP for www.abc.com for internal users) which is serving my internal clients. The CSS then points to actual server hosting abc.com. The ACE is serving clients coming from Internet and CSS is serving my internal clients which connect with http. Is this problem because of communication issue between ACE and CSS?
Can anybody suggest?
Jorge Bejarano
Level 10
Level 10
Could you try?
  webhost-redirection "https://abc.com/xyz" 301
  inservice
  webhost-redirection "https://abc.com/uvw" 301
inservice
It might be possible the redirect is working but maybe the other portion is not.
Could you upload the VIP?
Jorge
Could you add the configuration once the traffic is redirected?
class-map match-all intranet
  2 match virtual-address 198.184.231.7 tcp eq www
class-map match-all ssl-intranet
  2 match virtual-address 198.184.231.7 tcp eq https
I have 2 different policy maps .........intranet map redirects to ssl-intranet map which then makes redirection to individual applications.
policy-map multi-match external-lb
  class extranet
    loadbalance policy extranet
  class ssl-extranet
    loadbalance policy ssl-extranet
Yogesh Gawankar
If CSS VIP (1.1.1.1) is listening on http, I do not see port 80 in  the serverfarm config on ACE.
Hi Yogesh,
Requests come on 443...CSS offload it to 80 and sends to serverfarm
