ACE Redundancy - Two Module
majaj
i have two ACE Module in different chaisses
i want to make Data-Center1 primary for all contexts and Data-Center2 standby for all contexts
there is no commands Primary unit and standby unit like FWSM
how to acheive that?
Roble Mumin
Level 7
Level 7
You achieve this by associating a priority to each FT group.
Example:
ft group 1
peer 1
priority 150
peer priority 110
associate-context Admin
inservice
ft group 2
peer 1
priority 150
peer priority 110
associate-context Foo-Bar
inservice
That's all you need. For further details have a look at the ACE-Admin Guide.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/administration/guide/redundcy.html#wp999520
Roble
thanks
what about SSL Certificat and SSL Key does they replacated to the second ACE or we need to export and import them to the second ACE
You'll need to export and re-import into the contexts on the second ACE. If there is a difference in the files then replication will stop working.
Cathy
Yup, certificates and keys have to be manually imported on both ACE's.
Roble
