ACE Remote Access with Strong Encryption
tim_roper
Level 3
Level 3
How can you force the ACE to use a strong cipher for remote management through an HTTPS session?  After viewing an SSLScan of the admin interface, multiple 56 and 40 bit ciphers are being allowed...
sslscan --no-failed 10.10.10.10 | grep -i accepted
    Accepted  SSLv3  168 bits  EDH-RSA-DES-CBC3-SHA
    Accepted  SSLv3  168 bits  DES-CBC3-SHA
    Accepted  SSLv3  128 bits  DHE-RSA-AES128-SHA
    Accepted  SSLv3  128 bits  AES128-SHA
    Accepted  SSLv3  128 bits  RC4-SHA
    Accepted  SSLv3  128 bits  RC4-MD5
    Accepted  SSLv3  56 bits   EDH-RSA-DES-CBC-SHA
    Accepted  SSLv3  56 bits   DES-CBC-SHA
    Accepted  SSLv3  40 bits   EXP-EDH-RSA-DES-CBC-SHA
    Accepted  SSLv3  40 bits   EXP-DES-CBC-SHA
    Accepted  SSLv3  40 bits   EXP-RC4-MD5
I have tried to create an SSL parameter map, but I don't know where to apply it for remote access.
Tim
Daniel Arrondo Ostiz
Hi Tim,
The SSL parameter maps apply only to load-balanced connections. For management, the only thing you can do is enable/disable access. The cipher list cannot be modified.
I wish I could give you a more satisfactory answer.
Daniel
Marvin Rhoads
This sounds like you are trying to verify and enforce security compliance based on a scan. Perhpas it would be acceptable to put an ACL on your management interface and then enforce use of strong ciphers on the client end (as opposed to the ACE end) with something like a GPO or manual configuration.
