ACE replication connection
r.shummoogum
Level 3
Level 3
Hi:
What is the equivalent of "replicate CSRP connections" for ACE?
CSM CONFIG:
vserver TEXT
  virtual 10.10.10.1010 any
  vlan 88
  serverfarm TEXT
  replicate csrp connection------------------------>>>>>>
  persistent rebalance
  inservice
Surya ARBY
Level 10
Level 10
The ACE failover is stateful by default.
To configure replication for stickyness, configure it in your sticky group depending on the persistence method you want.
Surya ARBY
Level 10
Level 10
r.shummoogum
Level 3
Level 3
Thanks/Merci
