ACE: Routing in addition to Loadbalancing
s.srivas
I'm planning to route some traffic while loadbalancing other traffic.
For guidance, what can I refer for simple routing in ACE.
In addition, both routing and loadbalancing traffics need to pass a same Vlan in the ACE.
In the attached Steps 1,2,3 doing loadbalancing via vlan80
Steps 4,5,6 doing routing via same VLAN 80
Is simple routing possible in ACE?
SS
Gilles Dufour
as long as you permit the traffic with an access-list inside the access-group, ace will route the traffic that does not match any class-map.
This is the default and no particular config is required.
Gilles.
s.srivas
Attaching a digram relating to the above querry.
Gilles Dufour
Gilles.
