ACE same old thing cant ping VIP
dlance
here is config
we are trying to load balance non standard ports
rservers and vserver all show as up
but vip can not be pinged and no connections flow
logging enable
logging timestamp
logging buffered 3
resource-class RC1
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum unlimited
boot system image:c4710ace-t1k9-mz.A5_1_2.bin
login timeout 60
interface gigabitEthernet 1/1
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/2
  switchport access vlan 1001
  no shutdown
interface gigabitEthernet 1/3
  ft-port vlan 100
  no shutdown
interface gigabitEthernet 1/4
  shutdown
clock timezone standard EST
clock summer-time standard EDT
context Admin
  member RC1
ntp server 208.44.49.1
access-list ALL line 8 extended permit ip any any
access-list ALL line 9 extended permit icmp any any
probe http ghh-http
  port 8888
  interval 5
  passdetect interval 5
  request method head url /ProbeTrigger/probetrigger.htm
  expect status 200 200
  connection term forced
probe icmp ghh-icmp
  interval 5
rserver host ghh-1
  ip address 172.16.2.137
  conn-limit max 4000000 min 4000000
  inservice
rserver host ghh-2
  ip address 172.16.2.138
  inservice
rserver host ghh-3
  ip address 172.16.2.139
rserver host ghh-4
  ip address 172.16.2.140
rserver host ghh-5
  ip address 172.16.2.142
rserver host ghh-6
  ip address 172.16.2.143
rserver host ghh-7
  ip address 172.16.2.144
rserver host ghh-8
  ip address 172.16.2.145
serverfarm host ghh
  predictor leastconns
  probe ghh-icmp
  rserver ghh-1 30037
    inservice
  rserver ghh-2 30038
    inservice
  rserver ghh-3 30039
  rserver ghh-4 30040
  rserver ghh-5 30042
  rserver ghh-6 30043
  rserver ghh-7 30044
  rserver ghh-8 30045
parameter-map type http CASE_PARAM
  case-insensitive
  persistence-rebalance
parameter-map type generic case_generic
  case-insensitive
class-map type management match-any TO-CP-POLICY
  2 match protocol icmp any
  3 match protocol telnet any
  4 match protocol snmp any
  5 match protocol ssh any
class-map match-all ghh_CLASS
  2 match virtual-address 172.16.2.225 any
class-map type generic match-any ghh_generic
class-map type http loadbalance match-any ghh_http
  2 match http url [.]*
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match TO-CP-POLICY
  class TO-CP-POLICY
    permit
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance generic first-match ghh_POLICY
  class class-default
    serverfarm ghh
policy-map multi-match ghhpolicy
  class ghh_CLASS
    loadbalance vip inservice
    loadbalance policy ghh_POLICY
    loadbalance vip icmp-reply
    appl-parameter generic advanced-options case_generic
service-policy input TO-CP-POLICY
interface vlan 1000
  bridge-group 15
  access-group input ALL
  service-policy input remote_mgmt_allow_policy
  service-policy input ghhpolicy
  no shutdown
interface vlan 1001
  bridge-group 15
  no shutdown
interface bvi 15
  ip address 172.16.1.202 255.255.0.0
  peer ip address 172.16.1.203 255.255.0.0
  no shutdown
ft interface vlan 100
  ip address 192.168.10.11 255.255.255.0
  peer ip address 192.168.10.12 255.255.255.0
  no shutdown
ft peer 1
  heartbeat interval 300
  heartbeat count 20
  ft-interface vlan 100
ft group 1
  peer 1
  priority 200
  associate-context Admin
  inservice
ft track interface track_vlan1000
  track-interface vlan 1000
  peer track-interface vlan 1000
  priority 200
  peer priority 100
ip route 0.0.0.0 0.0.0.0 172.16.1.2
20 Replies 20
More information and the question of what was changed in 5.x software from 3.x software
first is new lb with 5.x software
note it thinks it trunking to another vlan which doesnt exist in our network
vlan1010 is up, VLAN up on the physical port
  Hardware type is VLAN
  MAC address is e8:9a:8f:b2:94:b3
  Virtual MAC address is 00:0b:fc:fe:1b:01
  Mode : transparent
  Bridge group number: 20
  FT status is active
  Description:not set
  MTU: 1500 bytes
  Last cleared: never
  Last Changed: Tue Aug 21 08:03:57 2012
  No of transitions: 3
  Alias IP address not set
  Peer IP address not set
  Assigned on the physical port, up on the physical port
  Previous State: Tue Aug 21 08:03:18 2012, VLAN not up on the physical port
  Previous State: Tue Aug 21 07:48:36 2012, BVI up
this is from our other ACE with 3.x software
vlan1000 is up, BVI configured
  MAC address is 00:1b:24:3d:b3:66
  Mode : transparent
  Bridge group number: 15
  FT status is active
  Description:not set
  MTU: 1500 bytes
  Last cleared: never
  Last Changed: Sun Jun 17 03:30:02 2012
  No of transitions: 1
You got configuration seems to be have redundancy, then I assume that your design is indeed like this, correct?
FIREWALL (gateway)
SWITCH
ACE1/ACE2
SWITCH with web servers
(ACE3/ACE4)
SWITCH with search servers
I assume you are working on ACE1/ACE2, right?
You may consider to apply these changes:
   switchport trunk allowed vlan 1010,1011
  no shutdown
  no shutdown
interface bvi 20
  description Client and server bridge group 20
  no shutdown
interface vlan 1010
  mac-sticky enable
  mac-address autogenerate
  bridge-group 20
  no shutdown
interface vlan 1011
  mac-sticky enable
  bridge-group 20
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.16.1.X
Yes its a FT group. and the FT group seems to work fine.
I have opened a TAC case.
Dave
Hello Dave,
In general when you have a topology like with 2 groups of ACEs not related, it is recommended to try to have different ft group number for each one.
FIREWALL (gateway)
SWITCH
ACE1/ACE2
(ACE3/ACE4)
I am happy the issue is fixed now
Jorge
Yes changing the group ID fixed the problem
Dave
Yep
