ACE: Scripted probes not working
danger_mousie
Level 3
Level 3
I have configured an LDAP probe using the script provided. It is stuck in INIT state saying that No. Internal error: is incrementing. I have tried script LDAP_PROBE DEBUG but I don't know how to view the debug output. I have logging up and running and can see my TCP and ICMP probe activity. The LDAP server is definitely working.
Update: I have tested the FTP_PROBE too and that is also stuck in INIT state with internal errors. Can I test scripts from the command line? I know that I have the correct arguments with the script.
Please can you help, Let me know if you need more info.
Thanks.
probe : FTP_Test_Probe
type : SCRIPTED, state : ACTIVE
description :
port : 21 address : 0.0.0.0 addr type : -
interval : 10 pass intvl : 5 pass count : 3
fail count: 3 recv timeout: 10
script filename : FTP_PROBE_SCRIPT
--------------------- probe results --------------------
probe association probed-address probes failed passed health
rserver : FTP_Test
1.1.1.10 0 0 0 INIT
Socket state : RESET
No. Passed states : 0 No. Failed states : 0
No. Probes skipped : 0 Last status code : 30007
No. Out of Sockets : 0 No. Internal error: 297
Last disconnect err : -
Last probe time : Never
Last fail time : Never
Last active time : Never
danger_mousie
Level 3
Level 3
It seems the script did not load into memory properly. I had run the scrip file 10 LDAP_PROBE command but it was not there when i tried to find it.
