ace snmpset
fd_case17
Level 3
Level 3
hi ,
Is it possible to modify conf with snmp on ace module like others 6500 catalyst ?
Is ace answer to snmpset cmds ?
thankx
chrhiggi
Level 8
Level 8
Hello FD case17,
  ACE only utilizes SNMP to send traps or monitor via SNMP polling of OIDs/SNMP Walking.  Use the XML API to setup configuration - https://supportforums.cisco.com/docs/DOC-17849
Chris Higgins
