ACE snmpwalk not return values for CISCO-SLB-MIB
sannitigsan
Hi everyone,
I need some help with snmp for the ACE. I am unable to get any results when running an snmpwalk for the object slbVServerClientByteCounts.
In fact, I get no results for anything related to CISCO-SLB-MIB. I can run an snmp translate against this mib and I am able to get the OIDs but when I run an snmpwalk against the ACE I get nothing for this mibs. I do however get results for the mibs: SNMPv2-SMI, IF-MIB, IP-MIB etc..etc..
My main goal is to get the traffic going to the virtual server vip and then graph it. I need to use the CISCO-SLB-MIB to do this.
Can someone please help? I will try and answer your questions to the best of my knowledge.
Thank you.
9 Replies 9
sannitigsan
Is it possible that the ACE does not have this mib loaded onto it? I searched the "Mib Support and Software" section for my IOS c4710ace-mz.A3_2_5.bin and nothing came up. In fact, it came up invalid and I can not find any info on the ACE and the mibs that it supports...
yeesh, I've been at this for over 5 hours now. SNMP is supposed to be simple...that's what the 'S' is for!
Hi Daniel,
The CISCO-SLB-MIB is supported in A3.2.5, so, you should not have any problems polling data from that particular mib.
One thing to take into account is that this mib will only return the information for the context where it's being polled, so, make sure you are polling the context where the vservers are configured.
Another thing you can try is doing a snmpwalk on the full mib (
1.3.6.1.4.1.9.9.161) to confirm whether some other OIDs can be polled for that mib or not.
Daniel
Thank you for your reply!
"One thing to take into account is that this mib will only return the information for the context where it's being polled, so, make sure you are polling the context where the vservers are configured"
I'm sorry but I don't understand this part. The vservers are configured on the ACE and I'm polling the ACE's ip.
"Another thing you can try is doing a snmpwalk on the full mib (1.3.6.1.4.1.9.9.161) to confirm whether some other OIDs can be polled for that mib or not"
I did this and yes it came up with a lot more results. I did not know that an snmpwalk defaults to the mib-2 tree if you don't specify the oid start. There many results but one of the oids i wanted was not there (slbVServerIndex). This is marked as "not-accessible" on the cisco webpage. I need this oid so I can specify which vserver to monitor the traffic on. I am begning to think what I want to do is not possible.
What I meant is that the ACE can have different contexts configured. In that situation, when doing the SNMP request, you need to do it against the IP address of the context where the vservers are configured. Once you do it, you should be able to poll the data.
Here is an example from my lab showing the snmpwalk on the vserver table (with 2 vservers configured):
root@ubuntu-server-1:~# snmpwalk -v 2c -c public 172.21.30.6 1.3.6.1.4.1.9.9.161.1.4
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.2.1.95 = STRING: "static_http"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.2.1.167 = STRING: "ftp"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.3.1.95 = STRING: "int530"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.3.1.167 = STRING: "int530"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.4.1.95 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.4.1.167 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.5.1.95 = STRING: "Operational"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.5.1.167 = STRING: "Operational"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.6.1.95 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.6.1.167 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.7.1.95 = Counter32: 364868
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.7.1.167 = Counter32: 248
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.8.1.95 = Counter32: 1
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.8.1.167 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.9.1.95 = Counter32: 2187381
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.9.1.167 = Counter32: 1306
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.10.1.95 = Counter32: 1457801
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.10.1.167 = Counter32: 1231
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.11.1.95 = Counter64: 134932830
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.11.1.167 = Counter64: 72023
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.12.1.95 = Counter64: 242218592
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.12.1.167 = Counter64: 764602
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.13.1.95 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.13.1.167 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.14.1.95 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.14.1.167 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.15.1.95 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.15.1.167 = Counter32: 0
And below, doing the same for only the slbVServerClientByteCounts OID:
root@ubuntu-server-1:~# snmpwalk -v 2c -c public 172.21.30.6 1.3.6.1.4.1.9.9.161.1.4.2.1.11
Interesting, I think we only have one context here. (I'm thinking context like PIX contexts)
So is 172.21.30.6 the vip of the vserver? I ask this becuase the vip does not belong to us, we only manage the ACE and the vip is in a subnet which belongs to the customer. I am currently using the managment ip in my snmpwalk.
By the way, thank you for your help. I am getting a much better understanding of this.
In the example, 172.21.30.6 is the management IP of the ACE for the context where the vservers are configured.
If I try to use the same command on the Admin context (which in my case doesn't have any vservers), I would just get an empty result.
Ok I fully understand. I have verified that I have only one context (Admin).
Would you be able to explain why I am able to see some oid data and nothing for others? Your results for oid slbVServerClientByteCounts is exactly what I am looking for.
This is what I have:
snmpwalk  -v 2c -c xxxxx 172.16.14.100  1.3.6.1.4.1.9.9.161.1.4.2.1
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.2.1.39 = STRING: "Port80"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.2.1.40 = STRING: "Port100"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.2.1.41 = STRING: "Port1010"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.2.1.42 = STRING: "Port21"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.2.1.43 = STRING: "Port444"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.3.1.39 = STRING: "test"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.3.1.40 = STRING: "test"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.3.1.41 = STRING: "test"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.3.1.42 = STRING: "test"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.3.1.43 = STRING: "test"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.4.1.39 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.4.1.40 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.4.1.41 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.4.1.42 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.4.1.43 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.5.1.39 = STRING: "Operational"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.5.1.40 = STRING: "Operational"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.5.1.41 = STRING: "Operational"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.5.1.42 = STRING: "No Active serverfarm(s) in Policy"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.5.1.43 = STRING: "No Active serverfarm(s) in Policy"
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.6.1.39 = Gauge32: 134
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.6.1.40 = Gauge32: 25
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.6.1.41 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.6.1.42 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.7.1.39 = Counter32: 510534985
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.7.1.40 = Counter32: 26901235
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.7.1.41 = Counter32: 86784
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.7.1.42 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.7.1.43 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.8.1.39 = Counter32: 128982
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.8.1.40 = Counter32: 3167
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.8.1.41 = Counter32: 7
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.8.1.42 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.8.1.43 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.9.1.39 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.9.1.40 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.9.1.41 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.9.1.42 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.9.1.43 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.10.1.39 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.10.1.40 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.10.1.41 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.10.1.42 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.10.1.43 = Counter32: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.11.1.39 = Counter64: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.11.1.40 = Counter64: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.11.1.41 = Counter64: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.11.1.42 = Counter64: 0
SNMPv2-SMI::enterprises.9.9.161.1.4.2.1.11.1.43 = Counter64: 0
Hi Daniel,
You are in fact getting results for all your vserves, but it's true that, the slbVServerClientByteCounts OID is returning 0 for each of the vservers:
Assuming you have traffic going through the device, I find it very strange that all of the counters remain at 0. This looks to me like a software bug, so I would recommend you to check if the issue persists after upgrading to the latest version, and if it does, opening a TAC service request to have it investigated further.
Daniel
Thanks Daniel. I appriciate all of your help.
