ACE ssl termination+java issue
tolulopebalogun
Visitor
Hi all,
i setup ssl termination on ACE module such that packects from client to ACE is encrypted(HTTPS) while, from ACE to the application servers is unencrypted (HTTP). When I connect to the VIP the attched error pop-up. Whereas connecting directly to the servers do not give such error.
Has anyone has similar experience? Can anyone help on resolving the issue.
Thanks.
sachinga.hcl
Level 10
Level 10
Hi Tolu,
First of all I would like to tell you this error is not related to ACE. So it would be better if you could try to find out this error either by googling or in ORACLE forums.
I try and find some references for you:
http://www.orafaq.com/forum/t/62003/2/
http://www.oratransplant.nl/2005/07/11/using-self-signed-ssl-certificates-with-jinitiator/
http://forums.oracle.com/forums/thread.jspa?threadID=243225
http://www.orafaq.com/forum/t/62004/2/
Could you  please try:
In Control Panel -> JInitiator administration console , the option "Use browser settings" has to be unchecked.
Sachin
sachinga.hcl
Level 10
Level 10
Hi Tolu,
Sachin
Thanks Sachin. I will try it out.
tolulopebalogun
Visitor
Thanks. The link below is helpful. But, just that it is not very scalable having to carry out the procedure for hundreds of client PCs.
