ACE sticky problem
chris
Level 2
Level 2
I have an issue with sticky server that I’m hope might just be a command I’m missing.
I am inserting a cookie and the sticky works fine.
When my browser has a successful sticky connection i take the server that has the sticky connection out of service. I try to make another connection, i see the connection round robin to all remaining servers but i don’t get a successful connection i do see the connection failure count increment on all other servers in the farm. Only when i bring the server back into service can i get a successful connection.
Any advice appreciated.
Sticky config below.
sticky http-cookie WEB-Cookie-1 WEB-Sticky-1
  cookie insert
  serverfarm WEB-SERVERS-80
Code
Version A3(2.0) [build 3.0(0)A3(2.0
Chris
5 Replies 5
stmccabe
Hello Chris, This will be an easy fix for you.  The command you are looking for is defined under the serverfarm inwhich you are creating sticky entries against.. You need to add a failaction.. I'm pasting the command syntax and options for the command.. Based on your breif description failaction purge will give you the desired result:
(config-sfarm-host) failaction
To configure the action that the ACE takes if a real server in a server farm goes down, use the failaction command. Use the no form of this command to reset the ACE to its default of taking no action when a server fails.
failaction {purge | reassign [across-interface]}
no failaction
Syntax Description
purge
Specifies that the ACE remove the connections to a real server if that  real server in the server farm fails after you configure this command.  The appliance sends a reset (RST) both to the client and to the server  that failed.
reassign
Specifies that the ACE reassigns existing server connections to the  backup real server, if a backup real server is configured. If no backup  real server is configured, this keyword has no effect.
across-interface
(Optional) Instructs the ACE to reassign all connections from the failed  real server to a backup real server on a different VLAN that is  commonly referred to as a bypass VLAN. By default, this feature is  disabled.
Hi Stmccabe
Thanks for the response unfortunately it hasn’t fixed my issue.
I have done some further investigation, subsequent connection from my browsers hit the ACE and increment the failure count on all other servers in the farm but i don’t believe any request is being sent to the farm.
If i delete my cookie from the browser i then get a successful connection to another server.
So i believe that the ACE is receiving my request, load balancing it to other servers in the farm and then rejecting the connection because the cookie value doesn’t apply to that server.
How do i work around this, have i not configured it correctly or is it a bug?
Chris
Hi Chris,
you can try to add "cookie insert browser-expire" so the coockie expires everytime the user closes the browser. This will make sure that the new request will stick to another server and not the server that is out of service.
Code:
If you want to avoid this problem you will need to wait for all the connection to complete after you gracefully shut down your server. Otherwise, if you have ssl and take rserver in server-farm outofservice while connections are active you will get disconnections and no service. On the other hand, if you dont have SSL configured and you take the rserver in server-farm outofservice, ACE will serve all current connections and will stop accepting new ones. So drain your server ahead of time if you have SSL Configured.
I think there is a way to put the rserver in serverfarm "inservice standby" this will not cause SSL connections to loose service rather it will gracefully shutdown the server allowing the SSL connection to finish and not accept new connections.
I hope it helps.
Kashman37,
Thanks for the suggestion, but same issue occurrs when i have the command present, i'm going for a software upgrade to rule that out.....
Quick update to say that upgrading the software fixed the issue, no alteration to configuration was required, thanks all for input and suggestions.
Chris
